coolent temp
Old Feb 7, 2003 | 07:36 PM
ydeer's Avatar
ydeer
Default coolent temp
i have just had my 1st drive in my modded c5. ARE stage 2 headers, comp cam 224/224, flp exhaust sys( exh headers,high flo cats, xpipe and int pipes. also have ls6 manifold, 178 degree stat. haltric tric intake ,with carbon mag. ported th. body (breathless ) also have engine covered with carbon fiber pieces, including the full one which covers the fuel rails and the intake man. (one piece) on the first drive after a few mi the dic came on and said coolent temp and as i was driving it read the temps. temp ranged from 190 to 226. the 190 was at 2700rpm and as fluctuating betweem 190 & 198 . when i got home and parked it shot up to 226 and after i opened the hood it went down to 214 (still running) why would this come up on the dic??? is that normal temps??could heat 9 in the eng. bay ) be triggering a sensor??? any suggestions :confused:
Old Feb 7, 2003 | 08:27 PM
SideStep's Avatar
SideStep
Default Re: coolent temp (ydeer)
ttt
I want to know also. Mine has never went over 225 at the hotest.
:cheers:
Old Feb 7, 2003 | 08:32 PM
vetterdstr's Avatar
vetterdstr
CA Events Coordinator
Those are normal temps :yesnod:
vetterdstr :cheers:
Old Feb 7, 2003 | 08:46 PM
lost's Avatar
lost
Default Re: coolent temp (vetterdstr)
Since I put in my t-stat mine never goes over 185, were your fans programmed to come on sooner?
Old Feb 7, 2003 | 08:52 PM
ydeer's Avatar
ydeer
Default Re: coolent temp (lost)
i guess my question is: why is the dic coming on and reading those temps??? :confused: :confused: :confused: :confused:
Old Feb 7, 2003 | 09:02 PM
Jim 47's Avatar
Jim 47
vetterdstr :cheers:
:iagree:
The fellow above, who's temp never goes above because of a low temp thermo, has clearly never driven his car hard - or is always going down hill at 30* weather at 1500rpm in 5th gear.
I have a 178* thermo in my 2000 FRC and normal street driving it is between 185 and 200 depending on haw much I am into the throttle. At the track on a hot day the coolant temp will get into the 220-230 range while moving and go even higher when coming off the track before it starts to go down. Hope this helps. :cool:
Old Feb 7, 2003 | 09:22 PM
vetterdstr's Avatar
vetterdstr
So you are saying that while you are driving and the DIC is blank... all of a sudden the temps display themselves for no reason?
vetterdstr :cheers:
Old Feb 8, 2003 | 05:39 AM
ydeer's Avatar
ydeer
VETTERDSTR, YES, that is what i am saying and that is what is happening. i don't know if the dic can be reprogrammed?
Old Feb 8, 2003 | 05:46 AM
vetterdstr's Avatar
vetterdstr
That is a weird situation... Never heard of that one before.. are you getting any codes that are related to coolant temp sensors?
vetterdstr :cheers:
Old Feb 8, 2003 | 04:57 PM
ydeer's Avatar
ydeer
no codes, just keeps coming on
[Modified by ydeer, 3:37 AM 2/9/2003]
To coolent temp
