Exhaust/Header Question
Old Feb 7, 2003 | 11:01 PM
Mavrick's Avatar
Mavrick
Default Exhaust/Header Question
I will be purchasing (finally) an after market exhaust, have narrowed it between the Corsa Indy's and the GLH. My question involes how loud will these be when I add headers. Planing on the FLP's this summer. I have read some posts where members have swapped down to the corsa touring when they added the headers as it was to loud with the indys. .
Anyone have the FLP's and the GLH exhaust? Did the addition of the headers make ot to loud (I know---TOO LOUD???)
Old Feb 7, 2003 | 11:08 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
Default Re: Exhaust/Header Question (Mavrick)
I have the FLP headers and GHL system.
To me, it is perfect. Loud enough to turn heads, but not excessively loud to worry about getting pulled over for it. Very deep and tough sounding both at idle, and it just screams at WOT in the higher RPM's, and no resonance inside the car. With the cruise set on the freeway, it is as quiet as stock inside the car. (unless accelerating).
I had the GHL system on first, added the headers later. They only made it somewhat louder under heavy acceleration, otherwise it sounds about the same.
If I were starting over, I would buy the same setup again without hesitation.
:cheers:
[Modified by Y2Kvert4me, 4:10 AM 2/8/2003]
Old Feb 7, 2003 | 11:25 PM
Mavrick's Avatar
Mavrick
Default Re: Exhaust/Header Question (Y2Kvert4me)
Y2K - thanks, was what I was hoping to hear. Have not heard anything bad about the GLH's and will probably go with these over the Indy's. Curious, what tips did you go with and did you do the install yourself?
Old Feb 7, 2003 | 11:44 PM
Y2Kvert4me's Avatar
Y2Kvert4me
St. Jude Donor '03
I have the quad 4" tips. They look great to me. I installed the GHL system myself (very easy 45 min job). The headers I had installed at FLP.
:cheers:
[Modified by Y2Kvert4me, 4:46 AM 2/8/2003]
Old Feb 8, 2003 | 12:42 AM
COBrien's Avatar
COBrien
Cruise-In III Veteran
St. Jude Donor '06-'07-'08
I just switched from Corsa Indy's to GHL's, and I have FLP headers. IMO both the Indy's and GHL's are equally loud (or equally quiet, depending on how you look at it :D).
Too loud vs. just right vs. not loud enough is obviously based on personal preference. IMO, both systems are about perfect in terms of volume. You can hear them at idle and cruise, but not to the point of causing the neighbors to hunt you down and set you on fire. But they get much louder as you get on the throttle. Which is :cool: :D.
I prefer the GHL's to the Corsa's because they have a much deeper tone; they sound as awesome at idle as they do at WOT.
Good luck!
Collin
Old Feb 8, 2003 | 02:46 AM
Ragtop_Rob's Avatar
Ragtop_Rob
St. Jude Donor '17
Default Re: Exhaust/Header Question (COBrien)
Y2K... Did you go with an X-Pipe on your GHL setup? If so did you also install that yourself? Those 4" tips look Fab on your car! :cool:
Old Feb 8, 2003 | 07:17 AM
Y2Kvert4me's Avatar
Y2Kvert4me
St. Jude Donor '03
Default Re: Exhaust/Header Question (Ragtop_Rob)
The FLP header system includes the X-pipe, so they installed it with the headers.
:cheers:
To Exhaust/Header Question
