need help with TQ converter quick
Old Feb 7, 2003 | 11:30 PM
rockgt302's Avatar
rockgt302
St. Jude Donor '05
Default need help with TQ converter quick
Will a vig 3200 need reprograming on the pcm on a 1998 C5. Will it throw a slip code. Some one is selling theirs off a camaro will it work on a C5.
Old Feb 8, 2003 | 09:26 AM
rockgt302's Avatar
rockgt302
St. Jude Donor '05
Default Re: need help with TQ converter quick (rockgt302)
ttt
Old Feb 8, 2003 | 12:48 PM
kp's Avatar
kp
if you dont change the gear you shouldnt get a slip code, as far as I know an ls1 f-body converter will NOT work in a C5, I believe an LT1 4L60e converter will though. I would call/e-mail a converter manufacturer to make sure..
It is honestly so much of a pain to swap converters in these cars I would go new unless you know exactly where it came from, the last vig I bought from tbyrne was here in 3 days. Swapping converters is not something you want to do twice on these.
[Modified by kp, 12:52 PM 2/8/2003]
Old Feb 8, 2003 | 06:35 PM
Face's Avatar
Face
Default Re: need help with TQ converter quick (kp)
IIRC, 99+ C5's are more prone to slip codes than your 98, so you should be ok. But as far as what's interchangeable with what, call the manufacturer.
To need help with TQ converter quick
