O2 sims install
Old Feb 8, 2003 | 10:01 AM
402Sam's Avatar
402Sam
Default O2 sims install
I am purchasing some O2 sims and was wondering how they installed. I know they plug into the wires going to the O2 sensors but once that is done do they also plug into the sensors somehow. If not do I need to remove the old O2 sensors and put the sims in their place. I am a little confused :confused:
Old Feb 8, 2003 | 10:17 AM
Rx7Rob's Avatar
Rx7Rob
Default Re: O2 sims install (sprayedc5)
O2 sims connect to the harness, not the sensor.
Old Feb 8, 2003 | 10:41 AM
MTWallet's Avatar
MTWallet
They plug into your harness and then you tie them up and away from the exhaust. If you want to remove your O2 sensors, you will have to install a plug in the pipe.
Old Feb 8, 2003 | 10:46 AM
402Sam's Avatar
402Sam
Default Re: O2 sims install (MTWallet)
I understand now, I couldnt figure out what you did with the O2 sims once they where plug in.
Thanks :cheers:
To O2 sims install
