Harness extension for 1 coil pack....
Old Dec 7, 2024 | 09:33 AM
grinder11's Avatar
grinder11
Default Harness extension for 1 coil pack....
I need a wiring harness extension for the coil packs. Actually only need 1, for just drivers side. Reason being I need to temporarily remove the coil pack from the valve cover. Doing this because I have a lifter issue. I want to be able to run the engine without the valve cover mounted so I can see just what is going on, and which lifter(s) is collapsing, or stuck. Thanks guys.....
Old Dec 7, 2024 | 09:37 AM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
Mike, just do a “clear flood crank” and you can watch the valve train !!…hold the gas pedal to the floor while starting the car and the engine will just crank…you will not get spark or injector pulse…you don’t need the engine running.
Old Dec 7, 2024 | 10:18 AM
grinder11's Avatar
grinder11
Hi Rob. I don't know if I can see what I need to see from the drivers seat. I don't have anyone I can trust to hold the pedal to the floor. With my luck, they'd let up on it slightly and send the cold engine to 7k!!!
Old Dec 7, 2024 | 10:26 AM
helga203's Avatar
helga203
How did you check pushrods??
Old Dec 7, 2024 | 10:53 AM
93Polo's Avatar
93Polo
CI 3-4-5-9 Veteran
Double check my googling as I have not tried this but looks like the coil takes the same connector as the flat O2 sensor wire.
https://www.bmotorsports.com/shop/pr...roducts_id/699
https://zcardepot.com/products/oxyge...ector-gm-style
Which means a O2 harness extension should work.
https://www.michiganmotorsports.com/...vette-5-7-6-2/
Where are you located?
My understanding is the main connector between the main harness and coil pack sub harness is the same on all LS motors but the connector beetween the coil pack and coil pack sub harness varies from coil pack to coil pack.
If you need longer and don't have the tools to pin your own harness, we were talking with EFI Connection to make a harness but the friend made his own connections.
Old Dec 7, 2024 | 03:53 PM
grinder11's Avatar
grinder11
With a checker. Problem is, theres no tick when coolant temp is under 160°. From there until 190°, it just starts tapping louder and louder. I need to find what lifter is collapsing/stuck......
Old Dec 7, 2024 | 03:54 PM
grinder11's Avatar
grinder11
Thank you.
Old Dec 7, 2024 | 04:51 PM
lucky131969's Avatar
lucky131969
Misfire history for a particular cylinder?
Checked exhaust mainfold/headers for cooler temp with an IR thermometer?
Old Dec 7, 2024 | 05:33 PM
helga203's Avatar
helga203
This kind of problem is the worst. Is it that bad you will not drive it??
Old Dec 8, 2024 | 12:15 AM
vette4fl's Avatar
vette4fl
You can get a stethoscope from Amazon for less than $20 in a couple days. I just bought one and it’s amazing.
Old Dec 8, 2024 | 09:03 AM
grinder11's Avatar
grinder11
Yes. I wont drive it. Wish I could post a sound clip or video, but the forum says it cant accept an MP4 file, so........
Old Dec 8, 2024 | 09:11 AM
grinder11's Avatar
grinder11
I have a stethoscope, but I havent tried using it yet. I'll give it a try in the spring. But it'd be tough to isolate the sound when the rockers are so close together. My plan is to do it visually, because I'd, hopefully, be able to see the excessive lash. I have to be able to access the valvetrain quickly so the engine doesn't cool off. If that happened, the noise will disappear. I'd leave the valve cover in place as long as possible, then remove it to inspect. The coil pack won't come off (IIRC) with the alternator still in place. Removing and replacing the alternator would just slow things down.
Old Dec 9, 2024 | 06:16 PM
grinder11's Avatar
grinder11
That's a good idea. I also have an IR thermometer. Not sure if I could discern a misfire history. When I plug in my old Predator, it says "random multiple cylinder misfire, cause unknown." Probably due to the cam. But the IR thermometer may help. Thanks, Lucky.
Old Dec 9, 2024 | 06:18 PM
grinder11's Avatar
grinder11
Car is in Michigan. Thank you.
Old Dec 9, 2024 | 06:28 PM
grinder11's Avatar
grinder11
@C5 Diag Hi Rob. I'm thinking I may just stick with jumping the TDR as we discussed before. Once it's hot, the lash problem could be found with the remote starter. I'll just leave it connected after checking all the zero lash pushrod lengths. Once it is started, Ill get it hot, shut it down, pull a valve cover, and spin it over until the problem manifests itself. Should only take a couple 3 or 4 spins. @lucky131969 I think Lucky had a good idea about using an IR thermometer. I cause the stethoscope to get to the general area, then see if it shows up with the IR thermometer. I still think its a lifter issue. Since it's such a PITA to access the lifters, I just want to be absolutely certain which lifter it is so I can fix it with just one more head removal. If this thing costs much more money, my wife will remove the head.....MINE!!!!!
Old Dec 9, 2024 | 07:20 PM
helga203's Avatar
helga203
Thats a simple fix. Just buy her jewelry that's more then what your spending on your car, then she can't give you ****. Learned this long time ago.
To Harness extension for 1 coil pack....
