When installing headers, what gaskets to use? O.E., or aftermarket?
Old Feb 8, 2003 | 11:26 AM
YELLOHHH's Avatar
YELLOHHH
Default When installing headers, what gaskets to use? O.E., or aftermarket?
Topic says it all. Also, for LS6 guys, since the exhuast ports are "D" shaped, and the headers are round, what is recomended? Thanks,
Greg
:cool:
Old Feb 8, 2003 | 12:34 PM
Ram Air Tony's Avatar
Ram Air Tony
Default Re: When installing headers, what gaskets to use? O.E., or aftermarket? (YELLOHHH)
I have used the stock OEM gaskets on 2 different header installs, and I just recently took off the headers (for clutch replacement) and used new OEM exhaust manifold gaskets.
Typically, the gaskets they send with new headers are paper, and the OEM ones have metal in them and seem to be better IMHO :)
having said that, my recommendation is to use the stock ones :yesnod:
hope that helps
Old Feb 8, 2003 | 01:05 PM
kp's Avatar
kp
I have uses the OE metal 'sandwich' gaskets on a lot of cars with no problems. On this car though I went with mrgasket ultra seals, these FLPs just wont seal with the metal gaskets for some reason. I have used the stock gaskets on FLPs on f-bodies without a problem though so who knows :cheers:
Old Feb 8, 2003 | 01:08 PM
CJS's Avatar
CJS
My dealer used the thick fiber gaskets that come with the FLP's, they are working just fine, even though the header flange was warped .090+.
Old Feb 8, 2003 | 03:28 PM
SNW Vette's Avatar
SNW Vette
Hi,
The stock 97-00 gasket has a round port and will match headers with a round port. The 01-03 gasket has an oval port which may leak at the bottom on some headers. My B&B shorties leaked using the late gaskets.
Good luck,
Steve
:seeya
Old Feb 8, 2003 | 04:08 PM
YELLOHHH's Avatar
YELLOHHH
Default Re: When installing headers, what gaskets to use? O.E., or aftermarket? (SNW Vette)
Thanks for the info guys, but my real question is, what is the best gasket to use to mate "D" shaped exhaust ports to "O" shaped header openings?
Greg
:cool:
Old Feb 8, 2003 | 04:41 PM
SwissVette_Joe's Avatar
SwissVette_Joe
@ALL
THANKS for sharing those essential infos. I am on the same walk as you all and shall keep the infos on record until final decision re Headers.
This Forum really rules !!
Thanks again, comrades, and be well. I wish you all a healthy CORVETTE Season with thousands of pleasing miles !!
Joe. :seeya
Old Feb 8, 2003 | 07:52 PM
SR71's Avatar
SR71
Default Re: When installing headers, what gaskets to use? O.E., or aftermarket? (SwissVette_Joe)
either should work,but I would use the round port gaskets since the header tube is larger than the port...the machined area around the exhaust port should be the same size regardless of port shape.
To When installing headers, what gaskets to use? O.E., or aftermarket?
