Option Codes DD0 & DD8
DD8: Mirror, Inside, R/V Light Sensitive
I have two C5's one is a 2001 Coupe and one is 2002 Convertible. Both have these option codes.
How can you tell if the outside mirrors are working as they should? I can't tell if the heaters are working on either car. It appears the passenger side mirror doesn't dim like the driver side on the 2002.
What circuit are they associated with?
Per this page from a 2001 manual, start the car and press the button to turn on the rear window defogger. Check temperature on the mirrors after a minute or two. If they have warmed significantly they are working.
