Transmission fluid - manual
Old Dec 10, 2024 | 11:14 PM
emptnest's Avatar
emptnest
Default Transmission fluid - manual
Approx 5 years ago, I had a well known Mid Atlantic driveline specialist rebuid and upgrade the 6speed manual transmission in my 1999 Corvette. It is an HPDE track car, with about 390 rwhp.
Since then, and following their recommendation, I have used only AC Delco 88861800 fluid in it.
my understanding is that the synchros are sensitive to other fluids, and the above is necessary for that reason.
In a recent order for the above, a National racing parts retailer substituted and sent AC Delco 19540137
Is the substituted fluid an acceptable alternative, or should I remain with 88861800?
Old Dec 11, 2024 | 09:56 AM
lucky131969's Avatar
lucky131969
Not sure why they would make this substitution. GM 88861800 is still active and available. I also do not see cross-reference or information indicating 19540137 is a replacement.
Old Dec 11, 2024 | 10:01 AM
emptnest's Avatar
emptnest
Agreed, I have searched and find no cross reference to support the substitution.
it is a disappointing decision from a previously reliable supplier. And done without any explanation.
Old Dec 11, 2024 | 10:27 AM
lucky131969
I would tell them to send you a return label for that fluid. They should have asked you first. Customer service is a rare commodity these days.
Old Dec 11, 2024 | 10:42 AM
ariZona06's Avatar
ariZona06
I wonder if the rebuild and upgrade included the newer style of synchros that are able to tolerate synthetic fluid but I understand your desire to follow the builders recommendations.
Old Dec 11, 2024 | 10:47 AM
lucky131969
Originally Posted by ariZona06
.... but I understand your desire to follow the builders recommendations.
and GMs
Old Dec 11, 2024 | 04:08 PM
vette4fl's Avatar
vette4fl
Maybe check in with the builder and pick his brain…maybe a particular specification he looks for. Perhaps he can also suggest an aftermarket fluid/brand. There are great manufacturers out there like Amsoil, RedLine, and many other choices. Good luck 👍
Old Dec 11, 2024 | 05:12 PM
emptnest's Avatar
emptnest
I did check with the builder and he stuck to the recommendation for the original 88861800.
I’m not sure, but I think OEM stock synchros were used.
Old Dec 11, 2024 | 11:49 PM
Dads2kconvertible's Avatar
Dads2kconvertible
It's my understanding it was the cellulose blocking rings that some claimed deteriorated because of synthetic ATF. Sometime during the C5 run the blocking rings were changed to carbon fiber.
Old Dec 12, 2024 | 09:08 AM
captain vette's Avatar
captain vette
Don’t put that in your trans, return to sender
Old Dec 15, 2024 | 07:02 PM
emptnest's Avatar
emptnest
Absolutely amazing, and now beyond frustrating:
After returning the undesired substitute, I changed vendors and ordered the originally desired fluid from Amazon.
What did I receive? MORE of the undesired substitute!!!!!
I will return this flawed shipment as well. But it really has me wondering if GM has declared it an equal.
Geez…..
Old Dec 15, 2024 | 07:05 PM
lucky131969
Geez…..
I just ordered the p/n you want 3 months ago direct from Rock Auto. Don't order auto parts from Amazon....
https://www.rockauto.com/en/moreinfo...13630&jsn=1259
Old Dec 15, 2024 | 07:29 PM
emptnest's Avatar
emptnest
Great tip!! Thanks much !
Old Dec 15, 2024 | 09:15 PM
mike venth's Avatar
mike venth
mike v
Veteran: Marine Corps
found this info on trany fluids when I upgraded my clutch from c5 coupe to a c5 Zo6. ,, and every thing else back seeing how it
was all out and needed cleaning iside and out.
txdrivetrain.com/fluid-type-transmission-tremec-t56-tr6060-faq/
Old Dec 16, 2024 | 09:22 AM
Dads2kconvertible
Your link was broken for me but the Internet Archive has a copy.
Old Dec 16, 2024 | 11:43 AM
emptnest's Avatar
emptnest
Thanks Mike V and Dads 2k. Much appreciated!
Old Dec 16, 2024 | 12:11 PM
mike venth's Avatar
mike venth
mike v
I googled it and then went to there Q&A section. Great information about trany fluids and more.
To Transmission fluid - manual
Old Dec 16, 2024 | 11:29 PM
DetroitGS's Avatar
DetroitGS
That's pretty interesting that a non-synthetic ATF is recommended, and that a synthetic is *not* recommended.
https://www.txdrivetrain.com/fluid-t...56-tr6060-faq/
Cut and pasted from the link above:
Which type of fluid should I put in my Tremec T56/TR6060 transmission?
Non-synthetic ATF (automatic transmission fluid) only. It will say one or more of these things on the bottle and could be in small print on the back side.
  • Dexron/Mercon (Dex/Merc) equivalent
  • Universal ATF
  • Dex 3 ATF
Not Recommended:
  • MTF (manual transmission fluid)
  • Synchromesh
  • Gear oil
  • Synthetic ATF
  • Semi-synthetic ATF
  • Dex 4 or higher
  • Mixes of the above fluids
Why not use synthetic fluid? Isn’t it better?
We’ve concluded that synthetic ATF has additives which allow the synchro rings to slip a small amount, causing excessive wear. These additives are made to benefit an automatic transmission which has fluid under high pressure, unlike a manual transmission which isn’t pressurized. We’ve found that the life of the synchro rings is drastically shortened when using synthetic fluid.
I’ve used synthetic fluid in my transmission, and it feels fine. Do I need to change it back to non-synthetic fluid?
Theoretically, one could put nearly any type of oil in a Tremec transmission, and it will probably seem fine. While any oil will work to an extent, the issue is longevity of the synchro ring friction material. It will not last long with anything besides non-synthetic ATF.
Old Dec 17, 2024 | 07:16 AM
Prop Joe's Avatar
Prop Joe
I posted this in another thread...
I have a 98' with the "Paper blocker rings" I did hours and hours of research. In the end I went with the current GM/AC Delco Manual gearbox flavor. PN 88861800. Its a mineral based fluid. The Summit search engine does not list the C5 specifically, but does list this for all Tremec trans used in Corvettes C6 and C7 including the ZR1. In the comments section a couple C5 owners reported in using this fluid as well.
https://www.summitracing.com/parts/ADO-10-4033
GM Tech link on the subject:
https://web.archive.org/web/20140617...hlink/2009/05/
"TIP: Any vehicle that previously used DEXRON-III for a manual transmission or transfer case should now use p/n 88861800 (88861801 in Canada) Manual Transmission and Transfer Case Fluid."
Another tip:
"All licenses for DEXRON-III expired at the end of 2006 and will not be renewed. Fluids sold in the market after that date bearing claims such as "suitable for use in DEXRON-III applications" or similar wording should be avoided, because 'DEXRON-III' fluids are no longer checked and policed by GM and therefore may not be the originally tested and approved formulation."
YMMV
Edit: Out of stock at Summit. Scoggin Dickey has it in stock:
https://sdparts.com/i-19932885-genui...I3mUDAAJSH95MM
Old Dec 17, 2024 | 08:24 AM
Kubs's Avatar
Kubs
2024 C5 of the Year Winner - Modified
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
Im surprised people are still rebuilding the old transmissions with the crummy blocker rings... Its the perfect opportunity to put something better in while you have it apart, and use a much WIDER variety of fluids.
