"Abby Normal" High Oil Temp.....Help?!
Old Feb 8, 2003 | 03:25 PM
Mean Green's Avatar
Mean Green
CI III & IV Vote Ho
CI II, III, IV & V Vet
CI IV Bracket Champ
St. Jude Donor '03-'04
Default "Abby Normal" High Oil Temp.....Help?!
Ove the past two weeks I've noticed that my oil temp is higher than normal, especially considering these cooler FL temps we've been having :(
Also noticed the oil pressure to be about 10psi higher than normal :(
Any thoughts, thanks :cheers:
Old Feb 8, 2003 | 04:22 PM
davidfarmer's Avatar
davidfarmer
Default Re: "Abby Normal" High Oil Temp.....Help?! (Mean Green 2000)
I would consider doing and oil change and putting a new filter on. Sometimes you get a bad filter, it gets blocked, and the oil is forced through the bypass. If you don't need an oil change, just change the filter and top off the oil.
Dave
Old Feb 8, 2003 | 04:34 PM
Mean Green's Avatar
Mean Green
CI III & IV Vote Ho
CI IV Bracket Champ
Default Re: "Abby Normal" High Oil Temp.....Help?! (davidfarmer)
thanks David....I just recently did an oil change, but I have a stock of filters on hand and oil is "cheap insurance"....so I'll take your advice and change it when we get back from the track tomorrow evening :) :cheers:
Old Feb 8, 2003 | 06:00 PM
NJVetteGuy's Avatar
NJVetteGuy
:nono: change it BEFORE the track, why risk the motor racing? Plus, if you have a restriction in your filter, it's taking up a couple horsepower to push the oil past it :yesnod:
Old Feb 8, 2003 | 07:11 PM
Mean Green's Avatar
Mean Green
CI III & IV Vote Ho
CI IV Bracket Champ
Default Re: "Abby Normal" High Oil Temp.....Help?! (NJVetteGuy)
good point....I gotta go get ice and gas anyway, guess I'll throw it up on the ramps when I get back and swap out the filter :) :cheers:
Old Feb 9, 2003 | 08:58 PM
Mean Green's Avatar
Mean Green
CI III & IV Vote Ho
CI IV Bracket Champ
Well I changed the filter last nite before the races today and no change.....I know that the temps are "within" range but when you're an old-time mechanic/navy machinist, you get used to the fine tuned rythm of the equipment and I've done the same with the vette :)
I know how it should sound and what normal temps and pressure are at all times....so I know when I get an increase of 10 psi and at least 10 degrees increase in oil pressure and temps, I know something is up :(
Hopefully the dealer will agree, I only have about 6 weeks before the end of the warranty :(
Old Feb 9, 2003 | 09:07 PM
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
Hope your oil pump is not going south like it did on Jim Halls car back in 00 or 01! I don't remember the symptoms, have the dealer check it out.
[Modified by wallstAL, 6:11 PM 2/9/2003]
Old Feb 9, 2003 | 09:23 PM
batsallover's Avatar
batsallover
MG,
What are you oil temps now? :confused: In below freezing temps here in Cincinnati, my oil temps stay between 180*-184* and this running a 160* thermostat and Hypertech. Hopefully other's can chime in on their oil temps.
Old Feb 9, 2003 | 09:37 PM
Mean Green's Avatar
Mean Green
CI III & IV Vote Ho
CI IV Bracket Champ
Default Re: "Abby Normal" High Oil Temp.....Help?! (batsallover)
my temps were up to 207 on the way to the track and I ran all the way in od, and it was 54 degrees out :(
Old Feb 9, 2003 | 09:43 PM
batsallover
How about coolant temps MG? Where they normal?
Old Feb 9, 2003 | 09:50 PM
Mean Green's Avatar
Mean Green
CI III & IV Vote Ho
CI IV Bracket Champ
for the outside ambient temps we're experiencing right now, it was running high as well :(
my tranny temps were above 200 at the track as well
I'm just wondering what all this is a prelude to :(
Old Feb 10, 2003 | 05:36 AM
davidmax's Avatar
davidmax
I would check for debris clogging radiator.My 427 runs on the warmer side even on 50 degree days.I found switching to Red Line lubes lowered my summer temps by 15 or so degrees and it still gets to 190-195 in the winter.
Come 110 degree days I'll run at 205-215.With MO1 I run 210-225.
You may want to install a race radiator with integral oil cooler.Its not a miracle product but the radiator we sell at Xtreme M.S. does a great job at keeping things cool.
You will notice the oil and water temps are within 5% of each other or less.when standing in traffic it helps but being it needs air passing through,it works best at speed.A good example would be a 225 water and 220 oil it will stay that way with fans only.Get her up to 45+ mph and in 10 minutes they drop by12-15% where a stock setup just cant disapate that much heat.
They work great on my Z06 and mine has LPE Twin Turbos blowing a 427 C5R so if it works well on my car the results of a naturally aspirated motor in theory should be even more dramatic.
Please feel free to call us for advice Nate and Mike are wizards and may come up with more suggestions.If your water temp was HI as well I would suspect a T-Stat or even a pressure test on the coolant system but be sure your coolant level is full I check once every 7-10 days at fill up but its expensive and fast and Its harder to work on your own car owning a Mod shop than the Avge. guy with a credit card.You can click the Xtreme link and visit our web site or feel free advise wont cost YA!!.Good Luck Dave S.
Old Feb 10, 2003 | 08:01 AM
SideStep's Avatar
SideStep
Default Re: "Abby Normal" High Oil Temp.....Help?! (wallstAL)
[QUOTE]Hope your oil pump is not going south like it did on Jim Halls car back in 00 or 01! I don't remember the symptoms, have the dealer check it out.[QUOTE]
:iagree:
...but if it is, this would be a great time to swap in a new cam... :D
Old Feb 10, 2003 | 12:25 PM
Mean Green's Avatar
Mean Green
CI III & IV Vote Ho
CI IV Bracket Champ
Default Re: "Abby Normal" High Oil Temp.....Help?! (davidmax)
thanks man....I may just do that......when I get back to Tampa, I'll pull codes and see if there's anything there, if not.....it's off to the dealer it goes as I only have 6 weeks left under warranty and need some other stuff checked out anyway :)
Old Feb 10, 2003 | 06:06 PM
Mean Green's Avatar
Mean Green
CI III & IV Vote Ho
CI IV Bracket Champ
any other input :)
Old Feb 10, 2003 | 07:48 PM
TLewis4095's Avatar
TLewis4095
Radiator clogged w/debris! I clean mine every 2-3 months. Always full of grass/weeds/etc. :cheers:
Old Feb 10, 2003 | 07:55 PM
Snake Slayer's Avatar
Snake Slayer
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Default Re: "Abby Normal" High Oil Temp.....Help?! (TLewis4095)
:yesnod: Mark, I had the same issues and the radiator looked as if there was a birds nest in there. This is also a good opportunity to clean your votex filter :cheers: If you want to play it safe give Greg Costanzo at Roger Whitley a call an set up an appointment.
Cecil
To "Abby Normal" High Oil Temp.....Help?!
Old Feb 10, 2003 | 08:13 PM
Mean Green's Avatar
Mean Green
CI III & IV Vote Ho
CI IV Bracket Champ
Default Re: "Abby Normal" High Oil Temp.....Help?! (Snake Slayer)
thanks you two :D
I'll check that as soon as I'm back in town :)......hopefully it's that simple and Cecil, I gotta bring it in for the "cricket chirpping" and the top, but like y'all said, hopefully it's the radiator :D
Old Feb 10, 2003 | 08:22 PM
VNAMVET's Avatar
VNAMVET
Veteran: Marine Corps
207.............!!! Mine were 265 at the roadcourse (with air temps at 45) at Gainesville!! :eek:
My drive home today showed 221....but I hit a 140 today............... :chevy
Usually my temp is 207 with 10W30 Mobile 1. I use 10W30 rather than 5W30 cause I drive a bit hard........ usually. Oh yeah, I run 7 QTs also...............
Old Feb 10, 2003 | 09:38 PM
Mean Green's Avatar
Mean Green
CI III & IV Vote Ho
CI IV Bracket Champ
Default Re: "Abby Normal" High Oil Temp.....Help?! (VNAMVET)
I hear ya Craig and I wouldn't be "worried" had that been the norm for me, but like I mentioned, when I see a change like that, outside the norm of what I observe, then something's gotta be up :)
Old habit from standing watch in the engine room, history tracking and trend spotting ;) :D
