Can a column lock bypass fail?
Old Dec 19, 2024 | 11:55 AM
rellim51's Avatar
rellim51
Default Can a column lock bypass fail?
I need some help with my column lock bypass. (I have read through the column lock FAQ already)
The car (2001 Z06) had a column lock bypass installed 10ish years ago and it worked properly. The car sat in storage for the last 2 years with a dead battery. Now, When I start the car, I'm getting a "pull key for 10 seconds' message and a "service column lock" message. The car dies when I get over 2mph. I tried reinstalling the CLB following the proper installation instructions and I tried pulling the #25 fuse for 10 mins with no change.
Is it possible the CLB I have has failed? Where should I start on fixing the problem?
Old Dec 19, 2024 | 12:14 PM
lucky131969's Avatar
lucky131969
Anything electrical or mechanical can fail.
Post your codes.
Old Dec 19, 2024 | 01:56 PM
redzg's Avatar
redzg
If it’s an LMC unit, several members have had good experiences calling the company and getting recommendations.
Old Dec 20, 2024 | 11:50 AM
rellim51's Avatar
rellim51
I'm not sure what brand unit it is, it doesn't have any markings on it.
Old Dec 20, 2024 | 11:56 AM
ztheusa's Avatar
ztheusa
Veteran: National Guard
A CLB and LMC-5 are two different units that do the same thing.
The LMC-5 has a higher following today than the "old-guy" CLB.
Maybe.....remove the CLB and install the LMC-5.
Call Richard.................he knows, probably the best!
Old Dec 20, 2024 | 02:31 PM
Dave in Pa's Avatar
Dave in Pa
Following!!!!!!!!!!
Old Dec 20, 2024 | 05:45 PM
zz28zz's Avatar
zz28zz
I had the LMC-5 and it worked for a while then issue returned. Discovered there's a "brown wire mod". After that mod, no more issues. Apparently the extra mod only needs to be done on some cars.
Old Dec 21, 2024 | 02:23 PM
bjones7131's Avatar
bjones7131
If LMC5, I would remve and see if corrects problem. Recall done many yrs ago but not 100%. It may work without the mod.
Old Dec 28, 2024 | 01:29 PM
jbm6900's Avatar
jbm6900
You probably already know, but make sure you got 100% battery, low voltage even a lil w/ activate that problem
To Can a column lock bypass fail?
