Running Light Issue
Old Jan 6, 2025 | 04:56 AM
Chuck Fasst's Avatar
Chuck Fasst
Default Running Light Issue
Weird LF driving light problem with my '03. I have replaced both sides in the last year or so with the leds. Sometimes it does not come on with the ignition. Other times it shows a white light? Really? Other times it sits there flashing. These symptoms vary depending on whether the running lights or the headlights are turned on. At one time, I can't remember which side. I replaced it with a standard bulb. That ended up melting some plastic. 😡
Old Jan 7, 2025 | 09:09 PM
Skooter's Avatar
Skooter
Do you have a hyper flash module installed? It regulates the electrical system to make LEDs work with a system designed to use incandescents.
Old Jan 13, 2025 | 03:46 AM
Chuck Fasst
Default Hyper Flash Module: Never heard of it.
Is this the factory part, or some option?
Old Jan 13, 2025 | 08:21 AM
Skooter's Avatar
Skooter
It's an aftermarket part available from many vendors. Easy to install and cost about $40.
To Running Light Issue
