Is it best to cut the bushings or use longer bolts for the lowering process? Also how much can you lower in the front and rear just using stock hardware?
I would try the stock bolts first ... I think you'll find its just right.... I know I did.. front @ 26 1/4 and back @ 26 3/4 with the stock bolts/ cut bushings
Thats from the fender lip to the ground
That's exactly what I did and my measurements are the same.
