Advice on Window Regulator
Old Jan 7, 2025 | 03:52 PM
Trickskier's Avatar
Trickskier
Default Advice on Window Regulator
I need to replace the drivers side window regulator. Is there a specific manufacturer that anyone recommends?
OER
Dorman
VDO / Continental
Thanks in advice for your suggestions!
Old Jan 7, 2025 | 04:06 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
OEM...Dorman is the worst !!!...look at Rock Auto for an OEM.
Old Jan 7, 2025 | 04:08 PM
Trickskier's Avatar
Trickskier
I looked on Rock Auto - OEM is no longer available.
Old Jan 7, 2025 | 04:15 PM
C5 Diag's Avatar
C5 Diag
I don’t see SMP which is another Tier 1 supplier…you can try one of the “standard replacement” manufacturers but up to you what you want to buy.
Old Jan 7, 2025 | 04:35 PM
Trickskier's Avatar
Trickskier
Thanks for your help! I googled the OEM part number 10344131 and OEM didn't come up either.
Classic Industries carries OER
To Advice on Window Regulator
