TPIS headers...off road pipes, Xpipes.....
Old Feb 9, 2003 | 02:37 PM
Phil97SVT's Avatar
Phil97SVT
Default TPIS headers...off road pipes, Xpipes.....
Is there any gain to running a X pipe right off of the headers instead of straight pipes into your mid X pipe? Does this increase the scavenging effect?
Phillip
Old Feb 9, 2003 | 03:24 PM
Phil97SVT's Avatar
Phil97SVT
Default Re: TPIS headers...off road pipes, Xpipes..... (Phil97SVT)
For clarification of setups:
Setup 1:
TPIS headers -> MTI x pipe -> factory H pipe
Vs:
Setup 2:
TPIS headers -> 16" cat eliminators -> magnaflow X pipe
Some say that setup 1 works better because the x pipe helps exhaust scavenging. Anyone know about this?
Phillip
Old Feb 9, 2003 | 04:05 PM
EuG's Avatar
EuG
Phillip ,
Mine is a different setup, but for what it’s worth check out: http://forums.corvetteforum.com/zerothread?id=414442
Basically I picked up ~10 peak rwHP with X-pipe right behind the headers over the straight pipes (on big motor with 3” exhaust though)
(couldn’t find the 485rwHP run with straight pipes, so I used this 481rwHP, but the TQ curve is almost identical so)
(click it)
Old Feb 9, 2003 | 04:16 PM
johnC5's Avatar
johnC5
The best place for the X-pipe is 16-18 inches after the headers (according to an engine expert). He stated the problem on the C5 is this is not possible without removing/changing the cats ("off-road X-pipe").
Old Feb 10, 2003 | 10:39 AM
97C5ENVY's Avatar
97C5ENVY
I have the MTI off-road X-Pipe placed right behind the headers......and I actually lost a few HP & TQ at about 4000 rpms, and i didn't pick up any additional HP or TQ anywhere else. So the short answer is "it's not worth the $$$ or headache". IMO.
FYI, this dyno comparison was done on my '97 vette with MTI stage 2 heads, MTI Hammer Cam, and TPIS headers w/MTI off-road X-pipe......and nothing else was added, changed or deleted bewteen dyno runs except the off-road x-pipe.
Here's the dyno comparison. The Black TQ line and Green HP line are the "before" dyno and the Red & Blue lines are the "after" dyno.
Old Feb 10, 2003 | 05:44 PM
Phil97SVT's Avatar
Phil97SVT
I am having a X pipe custom made, should be here next week or so. I will hit the dyno and get some real results. The company was very informative and they said that most of the X pipes on the market aren't built correctly but they claim to have extensive experience with Nascar and high HP applications and he said I should definitely see a gain on the dyno.
Phillip
*cough*Dr.Gas*cough* :D
To TPIS headers...off road pipes, Xpipes.....
