Other maintenance items when replacing balancer
Old Jan 11, 2025 | 04:47 PM
Espi2's Avatar
Espi2
Default Other maintenance items when replacing balancer
Wanted to get some thoughts on other items to replace when doing the harmonic balancer. Already doing the OPS, belts and tensioners and crank seal. What about timing chain cover and front main seal - is that suggested or additional work to get access? Any other thoughts appreciated. Hoping to be one and done for a while.
Old Jan 11, 2025 | 05:09 PM
Eleven Bravo's Avatar
Eleven Bravo
I am putting in a new A/C compressor, while I'm adding the a/c pulley to my balancer.
Old Jan 11, 2025 | 05:31 PM
frodo84's Avatar
frodo84
Uneducated autodidact
How many miles on the engine? The mileage would help with suggestions.
Old Jan 11, 2025 | 05:32 PM
Espi2's Avatar
Espi2
good point - 110k miles.
Old Jan 11, 2025 | 05:36 PM
frodo84's Avatar
frodo84
I would do the timing chain/gear and oil pump for sure.....not interested in slipping in a cam? Also consider doing the water pump too.
Old Jan 11, 2025 | 05:39 PM
lucky131969's Avatar
lucky131969
Add pullies to the list. Unless that timing cover is leaking, I would leave it alone. If you have to change the timing cover gasket, you'll need oil pan gaskets too. You already mentioned the crank seal, so I'm not sure what you mean by "front main seal".
Old Jan 11, 2025 | 05:41 PM
Espi2's Avatar
Espi2
I could be wrong - is the front main seal
the same as the seal you do for the balancer?
Old Jan 11, 2025 | 06:02 PM
lucky131969
There is no front main seal.....just a crank seal in the timing cover.
Old Jan 11, 2025 | 06:06 PM
Espi2's Avatar
Espi2
ah ok, then that’s already on the list. Thanks for clarifying.
Old Jan 11, 2025 | 06:07 PM
lucky131969
Old Jan 11, 2025 | 11:12 PM
Eleven Bravo
I replaced my A/C compressor and tensioner.
Old Jan 12, 2025 | 12:10 PM
frodo84's Avatar
frodo84
Old Jan 20, 2025 | 08:44 PM
93Polo's Avatar
93Polo
CI 3-4-5-9 Veteran
I would not do the chain/gear unless you are swapping the cam.
Old Jan 25, 2025 | 04:16 PM
wydopnthrtl's Avatar
wydopnthrtl
I'm in the middle of a cam swap. While I'm in there.. I'm replacing the timing chain, Engine mounts, and my AC compressor as it went bad about 2yrs ago. I also took the rad and condenser out and am cleaning everything. (new condenser going back in). Oh and new foam seals in my Var-a-ram kit.
Old Jan 25, 2025 | 04:28 PM
lucky131969
Not like you had much choice on the radiator
To Other maintenance items when replacing balancer
