My 2000 coupe is one of the 5% that was produced without the foglights installed.
Beyond the obvious parts needed; lights, mount brackets and switch, will I need to have a wiring harness set-up (I planned on installing factory lights) or are the necessary wires and connectors already there waiting to be plugged into the lights?
Any guidance and part numbers would be a great help.
you will need to make the wiring from the lights to the under hood fuse box.....you can power it all at the fog light fuse (think it is #6 :confused: )
here are the parts you need:
FOG LIGHT INSTALL PARTS
Fog Light Switch (truck release also) – #12135155
Flare Nuts in frame -- #10281487 (2 req)
Bolts to hold lights -- #11514623 (2 req)
Fog Light (Driver Side) -- #10256959
Fog Light (Passenger Side) -- #10256960
