I had some fitting problems. I took out on scew near the fender so it wont scratch up the blackwing. Is this safe? Also with the blackwing, am I supposed to line up the little lip with the spot on the MAF (it MAF is diagnol and the plastic piece is touching the shroud). Should I square it out?
I also installed the relocated mat wire with drilling a hole in the silicone piece. I also drilled a hole near the mat sensor to fit my fuel pressure line. I gave it a rev took it down the block and back. I went back to it to drive it then I saw check engine light?
