MN6 Problems
Old Feb 9, 2003 | 06:43 PM
TOPGUN9's Avatar
TOPGUN9
Default MN6 Problems
A buddy of mine has a '97 coupe,and is now having problems shifting into first gear. He says the other gears are not as smooth shifting as before, also.
Any ideas? Could this be a problem with the aluminum forks in the MN6?
Old Feb 9, 2003 | 07:04 PM
6SPD98's Avatar
6SPD98
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18- '19
Default Re: MN6 Problems (TOPGUN9)
I'm kind of curious as to the responce you are going to get. It could be the hydraulic actuator (slave cylinder) for the pressure plate. I remember reading another post about the same problem. He found the hydralic fluid to be comtaminated and bleeding the clutch solved his problem. The fluid is a Dot 3 brake fluid which will develop a certain amount of condensation. He also found little pieces of a black substance which looked like pieces of the gasket in the cap. I hope it's not a serious problem.I'm sure the members of the forum will be as helpful as they can be.
:flag :steering: :flag
Old Feb 9, 2003 | 07:09 PM
ICULUKN-C5's Avatar
ICULUKN-C5
Default Re: MN6 Problems (vette#one)
I would have to say it may be time for a rebuild. If you bang gears something is bound to go. The 1-2 syncros are weak in the T-56 IMO. I am on my 3rd rebuild. My car sees alot of seat time, both on the street and at the track.
There are several companies that sell a stronger T56, but I dont have much info about them
Old Feb 9, 2003 | 07:10 PM
Thunder7's Avatar
Thunder7
Default Re: MN6 Problems (ICULUKN-C5)
I was thinking something with the synchros as well....definately need to have those checked out...and likely rebuild.
Old Feb 9, 2003 | 08:23 PM
speedyc5's Avatar
speedyc5
Flush the clutch! I think you will be ready to go.
It fixed my 2000.
:seeya :seeya :seeya :seeya :seeya
Old Feb 9, 2003 | 09:41 PM
rodney@rpmtransmissions's Avatar
0rodney@rpmtransmissions
Former Vendor
Default Re: MN6 Problems (speedyc5)
http://forums.corvetteforum.com/zerothread?id=486493
To MN6 Problems
