Broken pin
Old Jan 22, 2025 | 03:34 PM
hclaeson's Avatar
hclaeson
Default Broken pin
The pin on my radiator drain plug broke off. I checked the drained fluid and surrounding ground but unable to find it. I inserted a small magnet into the radiator plug hole and no pin.
I am not sure if the pin is in the radiator or not. Has anyone else had this happen? Any suggestions on what to do next?
Thanks in advance for any replies
hclaeson
Old Jan 23, 2025 | 12:04 AM
Moved to C5 Tech for some advice.
Old Jan 23, 2025 | 08:57 AM
03tripleblack's Avatar
03tripleblack
2024 C5 of the Year Finalist - Unmodified
If it was me, I'd replace the plug fairly soon. That pin holds the valve closed. I think they are available pretty much anywhere...Dorman, Amazon, etc
As far as the whereabouts of the pin...who knows? Most likely it went out with the draining fluid. If it's in the rad I doubt it'll go anywhere else....I doubt the coolant flow has enough energy to pick it up and send it through the system.
Old Jan 23, 2025 | 12:30 PM
hclaeson's Avatar
hclaeson
Thank you
To Broken pin
