The Factory Rear Goodyears check in at 26.7 inches tall. My new Pilot Sports check in at 26.1, a fairly significant difference :(
I know this will help my acceleration times (the shorter tire is like adding more gear) but my question will be how much will it affect it-do I technically have a "3.55 rear pinion" now...? How much will my speedo be off?
Well, the tire height is a 2.3% difference. Applied to the axle ratio, that would leave you with 3.49. You'll probably not notice the difference.
As for the speedo, it will read slightly faster than you are actually going. At legal speeds, the error factor would be within 2 mph, so consider it a slight built-in safety cushion.
kp is correct, you must program for speedometer accuracy when changing tire sizes. (This is a textbook example of a calibration value.)
tire size change: auto reprogram, 6-speed reprogram
gear change: auto reprogram, 6-speed not needed.
Note too that WSSs work in terms of vehicle speed. I haven't yet seen a way to recal the EBTCM for altered tire sizes or looked closely at the way it interfaces with WSS and VSS sensor signals. I did do the math at one point to get a better handle on what front and rear tire diameter combinations could be expected to cause problems and wasn't alarmed enough by what I saw to pursue it any further. Technically, there is some gray area regarding what all needs to and can be reprogrammed to accurately and completely correct for this. I think the EBTCM and PCM both need to be adjusted but we can only handle it for the PCM.
"technically" you still have a 3.42 R&P. The change in tire diameter will change your engine rpms Vs. road speed ratio just like a change in gearing, but this is only a 2.3% change. This will be like running a 3.50:1 rear gear set, with stock height tires. The speedometer will be off because of the tire change, it wil read higher than you are really going. :cheers:
