Hacked up fuel pump wiring
The schematic makes me believe there is a 4 pin connector with 2 grays, a blue and black that plugs directly into the pump.
But there are more connections in my case. This connector was plugged into an adapter joining to another connector and then a plug into the pump that has purple, red etc. wires. Nothing I see on the schematic. Here as you can see, the connector that matches the schematic color scheme is identified by the yellow arrow and where it was plugged in as indicated by the red.
Circled in green is where the ad hoc switched 12 volt wire was connected to one side of the cut gray wire. When I apply 12v to this the pump runs. But the gray wire leads away from the pump, not toward it.
Could there be some aftermarket pump controller in here? Maybe a mix of some aftermarket stuff and bad circuits?
Well whoever installed this probably wasn't too concerned about voltage drop because the power side was simply stripped and conductor stuffed into a relay slot in the fuse block and a relay stuffed inside to hold it.
But I'm correct in thinking the plug that connects to the fuel pump module is the one in the schematic, blue, black 2x gray right? Nothing else after at least from the factory.
