Vararam VR-B2
Old Feb 6, 2025 | 11:55 AM
Tactical_Pidgeon454's Avatar
Tactical_Pidgeon454
5th Gear
Default Vararam VR-B2
Hi everyone,
I was wondering if anyone has experience with the Vararam VR-B2 intake system for the C5.
Will it really give you a 40hp increase?
Is it a pain in the butt to install?
Thanks,
Tactical_Pidgeon454
Old Feb 6, 2025 | 03:05 PM
lucky131969's Avatar
lucky131969
Originally Posted by Tactical_Pidgeon454
Hi everyone,
Thanks,
Tactical_Pidgeon454
On a dyno and stock engine...no.....but if you live your life at the track, that's where it will shine.
It does make a great wet/dry vac if you ever encounter some high water though...
Old Feb 6, 2025 | 03:15 PM
ipuig's Avatar
ipuig
St. Jude Donor '09
Hi everyone,
Thanks,
Tactical_Pidgeon454
I had one on a prior C5. It is not worth the money or installation effort in my opinion. Will it really give you a 40hp increase? NO. Is it a pain in the butt to install? When taking into consideration the HP gains, and the increased care you must take to avoid ingesting water into your intake duct, YES.
Old Feb 6, 2025 | 03:46 PM
aaronc7's Avatar
aaronc7
- Yes kind of pain to install
- Fitment/quality is very meh, it feels cheap and seal against air filter/air cleaner was sus
- I know several guys first hand who have hydro locked motor because of the scoops, but where you live will have a big impact on how serious of a concern this is
- I like the concept of ducting in air from the front, but all things considered, I prefer a simple air bridge to air filter setup.
Old Feb 6, 2025 | 04:37 PM
pjdbm's Avatar
pjdbm
I have it on my 99, very little gain, a bit of a pain to install not that bad (less than 4 hours),
I have no issues with the Vararam
Old Feb 6, 2025 | 11:03 PM
Tactical_Pidgeon454
5th Gear
Okay, thanks
I live in SoCal so water ingestion probably won't be much of an issue
Old Feb 7, 2025 | 07:51 AM
lucky131969
Okay, thanks
...until it is
Old Feb 8, 2025 | 07:21 PM
Navy Blue 210's Avatar
Navy Blue 210
Like it would matter in the above situation if a C5 had a Vara Ram or not in 3 feet of water, IN A LEEVE!
Old Feb 12, 2025 | 02:02 PM
lucky131969
3 feet? WTF are you talking about? They were on the 101.
Old Feb 13, 2025 | 10:02 AM
grinder11's Avatar
grinder11
Most C5 owners don't take their cars out in the rain, especially in a rain where flash flood warnings are in effect. If you don't try to turn your Corvette into a yacht or submarine, your fine. 40hp? LMAO!! I have a 427 LS7 in my C5, and can assure you I haven't gained 40hp over the old setup. Maybe at 160mph you might gain 15hp, IDK. Yes, they aren't easy to install, but someone with decent skills can do it fairly easy. Just don't expect to be done in an hour or two. Yes, the sealing quality isn't the best, for sure. It would be a good idea to put a thin film of dielectric/silicone grease on each side of the filter sealing surface. If you're touring on vacation and run into a super heavy torrential rain, you're still OK. If you see standing water pull over and wait until it recedes.
To Vararam VR-B2
