Adj. fuel Pressure Question
Old Feb 10, 2003 | 12:35 PM
ALDOAVME's Avatar
ALDOAVME
Default Adj. fuel Pressure Question
What fuel pressures are giving good results? i was told 55psi but i just wanted to know if anyone has experimented and found a good all around setting, or if it makes any diffrence at all :cheers:
Old Feb 10, 2003 | 01:24 PM
UtahVince's Avatar
UtahVince
Default Re: Adj. fuel Pressure Question (ALDOAVME)
I am running a similar amount of intake mods like you have. I am running 58 psi. Anything less than 56 and I get Lean Condition codes popping up.
Old Feb 10, 2003 | 02:35 PM
tboneinsc's Avatar
tboneinsc
I also installed an adjustable fuel pressure regulator and set it at 54PSI as recommended. The results were that I lost over 3MPG on the way to the FL Cruise In from South Carolina. I reset it back to the stock 58PSI and the MPGs are back. I also believe it hurt my quarter mile times but I do not have a time slip since retruning back to stock pressure to back that up. My opinion right now is that I spent $100 on a useless mod.
To Adj. fuel Pressure Question
