coolant temp
Old Feb 10, 2003 | 01:33 PM
mozart's Avatar
mozart
Default coolant temp
I found that my top coolant hose was collasping on cool down awhile back but that it did not seem to effect coolant temps I thought. I had the hose, themostat and tank cap replaced uder warrantee and after a 1k miles or so now it seems as if the car does run a little cooler and cools down quicker in traffic when the fan kicks in, so it did make a difference. This only occurred on cool down and I would find the hose collasped prior to start up after the engine was cool. I was told that this was not uncommon as there was a problem with the early resivoir caps and that they redesigned them after 01.
Old Feb 10, 2003 | 02:32 PM
Corvette SSX's Avatar
Corvette SSX
St. Jude Donor '08
Default Re: coolant temp (mozart)
There was a thread here a couple of days ago like this. The solution turned out to be a new radiator cap.
