LS1 vs. LS6 timeframe
Old Feb 10, 2003 | 03:00 PM
krabtree13's Avatar
krabtree13
Default LS1 vs. LS6 timeframe
I'm a bit confused over exactly when the "general" made the switch from LS1 to LS6 components.was it exactly at the 2001 to 2002 model year or what.thanks in advance!!!
Old Feb 10, 2003 | 03:23 PM
Duck916's Avatar
Duck916
Default Re: LS1 vs. LS6 timeframe (krabtree13)
If you're talking about the use of LS-6 components in the LS-1, they started using the LS-6 block in the LS-1 motors during the early part of the 2001 model year. The LS-6 manifold crossed over around the same time, I believe.
If you're talking about the introduction of various components to the LS-6 itself, the first changes occurred in 2001 with the introduction of the LS-6 and then there were more changes in 2002 when the LS-6 horsepower rating climbed from 385 to 405. The later changes included sodium filled exhaust valves, higher lift cam, revised airbox cover, and revised cats which eliminated the pup-cats. None of these changes made it to the LS-1.
Old Feb 10, 2003 | 04:18 PM
kewlbrz's Avatar
kewlbrz
Cruise-In II Veteran
Cruise-In III Veteran
Default Re: LS1 vs. LS6 timeframe (Duck916)
Just a point to clarify. All 2001 LS1's received the same manifold as the LS6. It was not a interim change during that model year like the LS6 block was.
Old Feb 10, 2003 | 04:48 PM
radstoy's Avatar
radstoy
I understand the LS6 block and intake became stock components in the second half of the 2001 production run. Mine was built 6/11/01 and understand it has both LS6 block and intake. :hurray:
Old Feb 10, 2003 | 05:19 PM
kewlbrz's Avatar
kewlbrz
Default Re: LS1 vs. LS6 timeframe (radstoy)
As I stated above, this is again misinformation.
The intake manfold was the same for the LS1 and LS6 since the very first 2001 came off the assembly line.
This is also heavily stated in all the GM literature material.
Old Feb 10, 2003 | 05:23 PM
flipm's Avatar
flipm
Default Re: LS1 vs. LS6 timeframe (kewlbrz)
Kewl,
Does this mean that all '02s have the LS-6 *block*? What is the difference between the LS1 and LS6 block?
Old Feb 10, 2003 | 06:11 PM
kewlbrz's Avatar
kewlbrz
Default Re: LS1 vs. LS6 timeframe (flipm)
Kewl,
Sometime during mid to late 2001 production, the LS1's began receiving the LS6 block. All 2002+ for sure have it.
The LS6 block is a somewhat stronger casting, and has windows in the bottom of the cylinders to help bay to bay breathing, to reduce resistance during high RPM operation. Thats about the major differences.
Since the beginning of 2001 all LS1's received the same manifold as the LS6.
[Modified by kewlbrz, 5:13 PM 2/10/2003]
Old Feb 10, 2003 | 06:31 PM
krabtree13's Avatar
krabtree13
Jeez,I'm starting to feel a little dumber than the average bear!I've got a 2002 coupe born on february 11,2002.If I understand your reply,my friend ,I've got the LS6 engine...correct?thank's for your expertise,Kewlbrz!!!
Old Feb 10, 2003 | 06:55 PM
kewlbrz's Avatar
kewlbrz
Youve got the LS6 Block, Heads, and intake/exhaust Manifold.
But not the LS6 heads, or LS6 cam, or LS6 programming.
Old Feb 10, 2003 | 10:48 PM
PaceThis's Avatar
PaceThis
What he said, except the heads (which he kind of corrected :)
Old Feb 11, 2003 | 06:46 PM
Myhardtop's Avatar
0Myhardtop
Former Vendor
Default Re: LS1 vs. LS6 timeframe (PaceThis)
What??? :cry
Old Feb 11, 2003 | 07:58 PM
CJS's Avatar
CJS
It should read:
Youve got the LS6 Block, and LS6 intake/exhaust Manifold, but LS1 Heads
Kewlbrez is one of our most knowledgable members on tech facts, so I am sure he just wrote it wrong
Old Feb 11, 2003 | 10:50 PM
kewlbrz's Avatar
kewlbrz
Default Re: LS1 vs. LS6 timeframe (CJS)
CJS, and Pace, thanks for fixing my syntax :cheers:
I definatly didnt mean to say the LS1 motors had LS6 heads :) :seeya
If that was the case, I would not have bought a set of LS6 heads from pacethis, for my LS1 ! :) :thumbs:
To LS1 vs. LS6 timeframe
