Could this tool help Pressure Sensor
Old Feb 21, 2025 | 07:57 AM
hyperv6's Avatar
hyperv6
Default Could this tool help Pressure Sensor
I am a very anti cut the cowl guy on changing the oil pressure sensor. That is just lazy. But if there were a tool to make it easier to remove the sensor and install a remote line I would before it.
https://www.summitracing.com/parts/vim-rfw100?rrec=true
I know it's not cheap but I can see many other things to use these on. It could tighten the remote fitting and not remove the intake.
I see it just as another option.
Old Feb 21, 2025 | 08:59 AM
jdmvette's Avatar
jdmvette
Night Owl for life
Old Feb 21, 2025 | 09:03 AM
captain vette's Avatar
captain vette
Just remove the intake
Old Feb 21, 2025 | 10:56 AM
LWSZ06's Avatar
LWSZ06
Don't see how this tool will help. You must get a ratchet and extension directly above the OPS to use. If you can do that, then you could use a sensor socket.
As stated above "Just remove the intake". It's neither hard or time consuming.
Old Feb 22, 2025 | 02:29 AM
Moved to C5 Tech.
Old Feb 22, 2025 | 08:24 AM
hyperv6's Avatar
hyperv6
Maybe I need to better explain.
#1 I’m very anti cutting a cowl hole.
But I know you can pull the sensor with a swivel.
My thinking is if you put in a remote kit you need to snug a line. A socket will not do that. You can start the line by twisting it and this tool will snug the fitting on a swivel.
This is not hard to do if you have a good set of tools. I also have a camera that can be used if needed.
I’m used to working on mid engines and to me changing the sensor is not that bad with the tools I have.
Old Feb 22, 2025 | 09:38 AM
lucky131969's Avatar
lucky131969
At this point, I bet you have spent more time reseraching and posting than would have been required to pull the intake and replace the sensor.
Old Feb 22, 2025 | 10:31 AM
grinder11's Avatar
grinder11
Amen to that. C5 intake has to be one of the easiest intakes I have ever removed......
Old Feb 22, 2025 | 10:44 AM
pjdbm's Avatar
pjdbm
Besides it being not hard of a job to do, after 20 years, things get dirty under there, also seals can be worn.
When it is opened up, it is a prime time to inspect/evaluate/replace things that need to be
Old Feb 22, 2025 | 11:41 AM
hyperv6's Avatar
hyperv6
Not at all. I saw this tool and just considered it as an option.
to be honest I have no leak and good pressure. I see tools and consider where they may help.
To be honest I can pull the intake as fast or faster than most here if needed.
Sorry I even made the suggestion to try to help someone or prevent another cowl getting cut.
Old Feb 22, 2025 | 11:54 AM
lucky131969
Prevent it? There are two types of corvette owners..."make it work".....and....."make it right". I agree that cutting a hole in the cowl is straight up douchebaggery, but you will never talk someone out of it. People like that live their whole lives taking short-cuts and hacking stuff up for the next car/home/boat ...etc owner to worry about.
Old Feb 22, 2025 | 03:31 PM
rrwirsi's Avatar
rrwirsi
Blasphemy, going straight to He** for cutting a access hole in the cowl. I suspect most DIY's on this forum has done some "make it work" stuff on their cars. I have. It is just a frigging car.
Old Feb 22, 2025 | 03:52 PM
lucky131969
Old Feb 22, 2025 | 05:44 PM
grinder11's Avatar
grinder11
Just a frigging car.....Yes, that's true. I remember asking my future father in law what he thought of Corvettes. He was a successful business owner and had a nice little collection. A 1927 Packard, a 1960 RWD Eldorado with factory Tri-Power, a Model A, etc. His answer wasn't what I was hoping to hear. He said "Corvettes? A plastic/fiberglass body on a glorified Chevrolet chassis." Ouch! But that quote reminded me of your frigging car comment....
Old Feb 22, 2025 | 06:56 PM
Ed Ramberger's Avatar
Ed Ramberger
See post 18. This is easy without removing the intake or cutting the car
\https://www.corvetteforum.com/forums...t-at-80-a.html
Old Feb 22, 2025 | 09:14 PM
twostepdon's Avatar
twostepdon
Unfortunately for my pocketbook I have the attitude that any excuse to buy a tool is a good excuse.
To Could this tool help Pressure Sensor
