headlight question
Old Feb 25, 2025 | 01:53 PM
bruceg2016's Avatar
bruceg2016
Default headlight question
A friend has a 2003 with 13k miles. One Headlight won't stay down. It closes but then pops back up. He said its not the gears, thanks!
Old Feb 25, 2025 | 02:52 PM
OUTAKTRL's Avatar
OUTAKTRL
Maybe the white plastic bump stops
Old Feb 25, 2025 | 02:53 PM
c5arlen's Avatar
c5arlen
So what is the (your) question?
Old Feb 25, 2025 | 04:49 PM
bruceg2016's Avatar
bruceg2016
my question is any idea's what it could be, maybe someone else experienced the same problem, thanks
Old Feb 25, 2025 | 05:17 PM
zz28zz's Avatar
zz28zz
That's what mine did when the gears stripped. Think it works by closing headlights until it bottoms out, motor current spikes, control module sees high current and turns off power. If gears are stripped when it bottoms, it doesn't hit high current (in the allowed time), then reverses by default causing light to pop back up.
If your friend replaces gears, get brass gears.
Old Feb 25, 2025 | 05:27 PM
Stingroo's Avatar
Stingroo
St. Jude Donor '20-'21-'22-'23-'24
He says it's not the gears - well, tell your friend he's wrong.
Old Feb 25, 2025 | 06:32 PM
bruceg2016's Avatar
bruceg2016
Thank you, I'm going to tell him to check the gears again
bruceg2016's Avatar
bruceg2016
will do!
Old Feb 25, 2025 | 11:13 PM
SkyTigress's Avatar
SkyTigress
My C5 was doing that a month after I bought it, the gears are made out of plastic and go bad. Tell him to get the brass replacement kit from Vette Nuts!
https://vettenuts.net/c5-corvette-br...r-gear-kit-new
Old Feb 27, 2025 | 09:48 PM
Moved to C5 Tech.
To headlight question
