Diff swap now trans issues.
Old Feb 25, 2025 | 02:00 PM
Bob__zombie's Avatar
Bob__zombie
Default Diff swap now trans issues.
Did the 3.42 swap then started having rev limiter issues with it bouncing before shift. Fixed it somewhat with my tuner. Now for some reason when I start driving the car, you can hear an audible difference in RPM. If I get on it when it does that it prevents it from hard shifting. If I don't, it'll hard shift. If I turn the car off, it goes away and I'm good until it decides to do it again. What am I missing?
Old Feb 25, 2025 | 02:25 PM
the_merv's Avatar
the_merv
That's a tune issue. Your tuner might be looking at it but he's overlooking a couple of tables.
Rear Gear Ratio needs to be set, as well as shift points now with the Rear Gear change.
Not sure what you mean you can hear the RPM difference, if you go to lower Gears the car will definitely sound different because it'll go through the RPMs faster to get to speed.
Hard shifts is from the line pressure being higher, if slip is sensed the PCM will bump line pressure up so the Transmission won't self destruct.
Scan it for codes see if any come up.
Old Feb 25, 2025 | 02:44 PM
Bob__zombie
I'll get the code when it pops up again. Just did the balancer so I had the battery pulled.
Any recommendations on a tuner that could do something remote? Or in Colorado?
Old Feb 25, 2025 | 07:35 PM
feeder82's Avatar
feeder82
When you mention tuner are you talking about a person or one of those handheld tuners? Those will not change the tables that need to be changed
Old Feb 25, 2025 | 07:53 PM
the_merv's Avatar
the_merv
Good catch, when I see someone say "my tuner" I think its someone on it with a laptop.
Old Feb 25, 2025 | 08:12 PM
Bob__zombie
Person. He used Hp tuners. But it's changed a lot with him manipulating the tables. I just don't trust his abilities since he was having to read the book to try and figure it out.
Old Feb 25, 2025 | 08:13 PM
Bob__zombie
I mean, that's what it was basically.
Old Feb 25, 2025 | 08:20 PM
the_merv's Avatar
the_merv
That's not a good sign. I used my cars for guinea pigs before I started tuning other people's stuff...​​​​​​​
To Diff swap now trans issues.
