TPS harness check
Old Feb 25, 2025 | 02:35 PM
Johnnyv49's Avatar
Johnnyv49
Default TPS harness check
Can someone point me to the thread that gives me the step-by-step for checking the TPS plug on a C5 Corvette. Can't seem to locate it
Old Feb 25, 2025 | 03:04 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
You are wanting to check the TPS sensor ??..I think I showed you how to check the APP sensor not to long ago…same test…it’s a potentiometer.
Old Feb 25, 2025 | 06:20 PM
Johnnyv49's Avatar
Johnnyv49
You are correct I keep forgetting that by testing that plug you are testing the signal coming from the pedal. My mistake I guess I kept thinking that the APP is tested only at the pedal.
Thank you I'll refer back to that previous post
Old Feb 25, 2025 | 06:27 PM
C5 Diag's Avatar
C5 Diag
The APP and TPS are 2 different sensors.
Old Feb 25, 2025 | 08:11 PM
the_merv's Avatar
the_merv
As mentioned it's a POT. 5v on one wire, Signal back to the PCM, Ground. Two separate ones in there, 6 wires.
Pic for reference of the location.
Old Feb 25, 2025 | 08:19 PM
C5 Diag's Avatar
C5 Diag
Old Feb 25, 2025 | 10:39 PM
the_merv's Avatar
the_merv
I commented on this earlier, for some reason my posts are in some kind of approval state at the moment, maybe that will get figured out.
Edited out duplicate info.
To TPS harness check
