Misfire
Old Mar 6, 2025 | 04:41 PM
Perplexed's Avatar
Perplexed
2nd Gear
Default Misfire
2004 C5 totally stock original owner, have about 25,000 miles on the car started to miss, my engine light went on code indicates random misfire. I put some Chevron injector cleaner in and one for about a 10 mile drive still misfiring and engine light flashing. Please advise what should I do first.
Old Mar 6, 2025 | 05:53 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
Below is what can cause a misfire…other than changing plugs and wires DIY’ers don’t have the necessary diagnostic equipment to properly diagnose without changing a bunch of parts !!…a flashing MIL is a cat damaging misfire…get is repaired ASAP.
  1. Plug
  2. Wire
  3. Coil Pack
  4. Coil Pack wiring
  5. Fuel Injector
  6. Fuel Injector wiring
  7. Fuel Injector wiring- bad ECM/PCM
  8. Valve Spring broken
  9. Burned Valve
  10. Cam Lobe worn
  11. Low Compression- Rings
Old Mar 6, 2025 | 09:58 PM
JDiv48's Avatar
JDiv48
Since you are the original owner of a 04 with 25K miles my first guess is plugs and wires. Age takes it's toll on the wires and at 21 years plugs and wires isn't a bad move or money wasted. .When mine hit 21 I started to have a rough idle at red lights with no codes. Plugs and wires smoothed it out. If you can do the repair yourself even better. #8 looks intimidating but it's actually pretty easy if you have a assortment of tools and you won't have to wiggle any tubes or move wires wires..
Old Mar 6, 2025 | 11:25 PM
Perplexed's Avatar
Perplexed
2nd Gear
Appreciate the info, took the engine covers off and the plugs and wires look like they’re more accessible then my Chrysler 300 with the Hemi and there’s only 8 plugs. I’ll start there before I find a shop to bring it to.
To Misfire
