I'm frustrated!!
Old Mar 10, 2025 | 01:58 PM
hgig66's Avatar
hgig66
5th Gear
Default I'm frustrated!!
I recently had a mechanic hunt down and oil leak on my 2000 c5.
He. Changed the rear main seal.
Fixed the oil leak BUT NOW when my headlights go up it
blows a fuse and i lose my tail/brake lights , my headlights and motor that puts them down and my trunk release. Change the fuse it good.
I've checked the grounds I could get too without disassembling. Then i tested the hazard switch . Since it was flapping around it was bad I changed it. Still same
I know it's gotta be going to ground somewhere I just got a wire tracker last resort.
Hoping I can get some input before I gotta go through all that.
thanks
Old Mar 10, 2025 | 02:26 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
When a fuse blows you have a direct short to ground…”checking your grounds” isn’t a way to find your short…what fuse is blown ??…my advise is find an auto electric shop in your area if you don’t have a solid knowledge of automotive electrical systems…unfortunately we can’t diagnose this for you.
Old Mar 10, 2025 | 03:35 PM
Fast one's Avatar
Fast one
Check the wiring for missing insulation and contact to metal that's grounded like the frame.
Old Mar 10, 2025 | 03:38 PM
TonyCorvette_'s Avatar
TonyCorvette_
thanks
If it were me, I’d unplug everything on the circuit, replace the fuse, and retest. If it still blows, you have bad wiring. If the fuse stays, start plugging one component in at a time and test it until the fuse blows.
Old Mar 10, 2025 | 09:10 PM
the_merv's Avatar
the_merv
Probably have a wire pinched somewhere when it all was put back together.
To I'm frustrated!!
