Felpro VS Factory head gaskets?
Old Feb 11, 2003 | 12:22 PM
jeffh355's Avatar
jeffh355
Default Felpro VS Factory head gaskets?
I need to get a top end kit for my car. Is there any reason not to save a few bucks and use a felpro kit from the local parts store?
Old Feb 11, 2003 | 12:30 PM
Chris@SD's Avatar
Chris@SD
Default Re: Felpro VS Factory head gaskets? (jeffh355)
Correct me if I am wrong, but I believe stock GM gaskets are way cheaper than the Felpro.
Old Feb 11, 2003 | 12:34 PM
jeffh355's Avatar
jeffh355
Default Re: Felpro VS Factory head gaskets? (Chris@SpeedDemon)
Oh....Ah...... Maybe I should have checked that before posting. Thanx I'm just used to getting reemed by the local dealer. :cheers:
Old Feb 11, 2003 | 12:54 PM
wwashing's Avatar
wwashing
To heck with the price, which is the better gasket? :cheers:
Old Feb 11, 2003 | 01:08 PM
Chris@SD's Avatar
Chris@SD
Default Re: Felpro VS Factory head gaskets? (wwashing)
Well, that is a difficult question, but for a stock engine with no machining, the stock gasket will be better. Idealy, you will want to use the gasket that the block was torque plate honed with as they all apply slightly different stresses on the block. I do realize that the factory engines are not torque plate honed, but the gasket that they used was designed with that in mind.
Long story short, Fel-pro for a built engine, Stock for the stock engine.
Good Luck, and we do have both of these gaskets in stock if you need either of them.
Old Feb 11, 2003 | 06:55 PM
Mike Morgan's Avatar
Mike Morgan
Fel9284PT is an OEM replacement gasket for the early style GM head gaskets. They are not the MLS style gaskets, but for heads not compatible with the MLS gaskets these are nice OEM style replacements.
If you can't find them from a local parts store, we have them in stock.
Old Feb 11, 2003 | 07:34 PM
jeffh355's Avatar
jeffh355
Default Re: Felpro VS Factory head gaskets? (Mike Morgan)
Thanx Mike. My car was the silver convertible you couldn't dyno a couple weeks ago due to the miss at idle. Looks like the the valve is bent. Should have had you tune it "before" I bounced it off the rev limiter a few times. I'm looking into a set of 5.3? heads off the pick ups that have been worked over for an LS1 application.:D
To Felpro VS Factory head gaskets?
