Installed LED taillights. Hyperflashing help.
Old Mar 15, 2025 | 05:16 PM
99FRC Newb's Avatar
99FRC Newb
Default Installed LED taillights. Hyperflashing help.
Hi everyone!
Everything on the front of my car is LED. I have a hyper flash relay installed. It was working fine.
I just installed LEDs in my taillights and I’m getting hyper flash again.
Do I need a second relay? Where would I plug it in?
Old Mar 15, 2025 | 08:19 PM
the_merv's Avatar
the_merv
I always put Resistors inline, LED's use less voltage.
Old Mar 15, 2025 | 08:24 PM
MSG C5's Avatar
MSG C5
2018 C5 of Year Finalist
I would try a new hyper flash relay under the steering column before installing resistors. I have a full exterior LED/HID setup and had to change out an aging hyper flash harness a couple of years ago when I swapped out my Halo tail lights to the Vette Lights laser tail lights.
Resistors generate a lot of heat and I didn't like that especially close to other wires, plastic trim, etc.
Old Mar 15, 2025 | 09:12 PM
the_merv's Avatar
the_merv
The LED Circuit is 12 volts and barely any amps, how much heat do you think a resistor will generate? I really want to know from your experience what you melted, compared to buying something not necessary because people will spend money on anything.
It's an LED, look up how much they draw. FWIW some of us do specialized electronics for a job, just sayin...
Old Mar 15, 2025 | 10:14 PM
99FRC Newb's Avatar
99FRC Newb
I have a hyper flash relay installed under the steering column already. That’s why I’m confused.
99FRC Newb's Avatar
99FRC Newb
Any specific ones you recommend?
Old Mar 15, 2025 | 11:00 PM
the_merv's Avatar
the_merv
Depends on what you installed, have to bring it up to the draw that the normal bulb would be.
Old Mar 16, 2025 | 12:10 AM
CFight's Avatar
CFight
My hyperflash came withit's own flasher (not yet installed) but I have a spare variable one from when i bought a pair for my motorcycle's hyperflash leds. You can set it to any tempo in a range.
Amazon Amazon
Old Mar 16, 2025 | 09:10 AM
99FRC Newb's Avatar
99FRC Newb
They’re just Sylvania bulbs from autozone.
Old Mar 16, 2025 | 10:45 AM
VetinaVette's Avatar
VetinaVette
Originally Posted by 99FRC Newb
Hi everyone!
I have LED lights all around including my headlights. I installed a hyperflash relay that goes between the circuit leading to my emergency blinkers button. The only downside is when I hit the emergency blinker button I get a fault code but not a huge deal, clear it and move on since I rarely use the flashers.
Old Mar 16, 2025 | 11:42 AM
Lowend's Avatar
Lowend
I had to do resistors on my C5 when I did the rear tails. Had been running from LED's and headlights for a year with a hyper flash module. Something about the rear tails requires more resistance.
That said, the resistors for the rear cost <$10/pair and take less than 30 min to install start to stop
Amazon Amazon
Old Mar 16, 2025 | 08:49 PM
MSG C5's Avatar
MSG C5
Understood, I had one as well, but it was over 10 years old and like other aftermarket parts, some are built better than others so I swapped it out to a new one provided by Sharplight Innovations and the hyper flash stopped. I'm not sure why the new Vette Lights LED tails suddenly caused my hyper flash to start after running other LED tails, but they did. Interestingly though, Vette Lights is the only supplier that I've purchased from that includes resistors with their kits. Perhaps it's because they have multiple lighting mode options, i.e. full illumination vs. laser lines, etc. vs. my previous front corner switchbacks and Halo ring tails. I received two resistors for the front corners and two resistors for the rear tail lights and all four are still in the box, so they do work with a hyper flash harness.
Old Mar 16, 2025 | 09:02 PM
MSG C5's Avatar
MSG C5
Not sure the temperature of the heat generated Mr. Science, however Vette Lights even suggested the hyper flash harness and not mounting the resistors to plastic or near other wiring so I took their advice...
https://www.vette-lights.com/product...7QDdsSxTYpgNO-
Old Mar 16, 2025 | 09:09 PM
the_merv's Avatar
the_merv
So you're here reading **** on the internet that's some company's disclaimer instead of actual experience..got it. Asking technical stuff is "science" eh, outside of your knowledge scope apparently.
It's ok, we all do different things.
Old Mar 16, 2025 | 09:25 PM
MSG C5's Avatar
MSG C5
No. I'm reading "****" from the manufacturer/vendor who I purchased the LED light kits from so maybe you should take your argument up with Vette Lights product development team unless that is "outside your knowledge scope." I'm just trying to help another C5 guy out who had the same problem with hyper-flash that I did and the solution that worked for me, unlike you who apparently just needs validation.
Old Mar 16, 2025 | 09:36 PM
the_merv's Avatar
the_merv
Couple other guys said resistors also, go mess with them too hero..
We gave a solution that isn't overpriced, then again if you don't have knowledge well you better have money I guess.
No validation needed here. I build stuff not buy it.
Old Mar 16, 2025 | 10:09 PM
MSG C5's Avatar
MSG C5
Yep. I'm loaded. $75 hyper flash harness vs. $25 in resistors. Gotta pay to play I guess.
I'm just surprised how any of us got anything done here before February, 2025. Seriously, thanks for everything. My life is changed for the better.
To Installed LED taillights. Hyperflashing help.
Old Mar 16, 2025 | 10:23 PM
the_merv's Avatar
the_merv
Get resistors for much cheaper than that. If you grew up building stuff and buying it at a Radio Shack you'd know that.
You have no clue who I am in the car community. When you un-*** your head, you'll figure that out. Surf through LS1Tech, get back to me. Been wrenching on stuff much more than you been buying it.
End of the day, guy asked for advice and several of us interjected. You said your piece because of what you read on the internets and I called it out with real world experience. That hurt your feelings apparently.
It's ok, if you never done it you just have to say that. Learn something new every day. You don't have to be big mad.
Old Mar 16, 2025 | 10:45 PM
99FRC Newb's Avatar
99FRC Newb
Thank you for the help, everyone. I didn’t expect it to turn into an argument. I’ve got it figured out now.
Old Mar 16, 2025 | 10:49 PM
the_merv's Avatar
the_merv
Good to see, there's a few ways to fix that one all on what you want to do.
Some people just like to argue, hands aren't busy building anything..
