oil pressure
Old Mar 25, 2025 | 07:47 PM
namvet6869's Avatar
namvet6869
Default oil pressure
Will heavier oil raise oil pressure a little??????????
Old Mar 25, 2025 | 09:28 PM
redzg's Avatar
redzg
Yes, but it can literally be a little. Going from 5W30 to 10W30 may get you 2 to 3 psi at idle. Not sure what 10W40 would get you, that strikes me as too much, though it may be the recommended viscosity for racing. I would think increasing the max cold viscosity, i.e. the 30 in 10W30, would be less help than increasing the minimum hot viscosity, since the motor tends to spend time at full temp.
Old Mar 26, 2025 | 08:28 AM
lucky131969's Avatar
lucky131969
What are you trying to achieve?
https://www.widman.biz/English/Tables/gr-motores.html
Old Mar 26, 2025 | 08:42 AM
grinder11's Avatar
grinder11
Thicker oil increases pressure by restricting flow, due to the higher viscosity. If the pump could move grease, pressure would be maybe 600psi, which means certain moving parts wouldn't get lubed. The only meaningful way to increase pressure would be to push a higher volume of oil thru the existing clearances. Or rebuild the engine with tighter tolerances.....
Old Mar 26, 2025 | 09:03 AM
grinder11's Avatar
grinder11
Originally Posted by redzg
Yes, but it can literally be a little. Going from 5W30 to 10W30 may get you 2 to 3 psi at idle. Not sure what 10W40 would get you, that strikes me as too much, though it may be the recommended viscosity for racking. I would think increasing the max cold viscosity, i.e. the 30 in 10W30, would be less help than increasing the minimum hot viscosity, since the motor tends to spend time at full temp.
The "30" in 10W-30 is NOT the cold viscosity! The 10w number is resistance to cold flow. The second number in multi-vis oils is the hot viscosity/resistance to flow, and the first number in multi-vis oils is the cold viscosity/resistance to flow....
Old Mar 26, 2025 | 11:58 PM
vette4fl's Avatar
vette4fl
The question raised was could heavier weight oil increase oil pressure. The answer is, probably.
Greater pressure is best determined by the oil pump specifications. The weight of the oil is best determined by clearance, load, heat transfer…an engineer.
Old Mar 27, 2025 | 09:57 AM
namvet6869's Avatar
namvet6869
My 2000 has 95000. When hot pressure is around 35 at highway and 15 -20 at idle. Decided against changing to heavier oil. Just went with Mobil 1 synthetic high milage 5w30.
Old Mar 27, 2025 | 10:49 AM
vette4fl's Avatar
vette4fl
That is kinda low. Next oil change try out Mobil Supercar 0w-40. This oil is recommended by GM for our engines.
Old Mar 27, 2025 | 10:57 AM
lucky131969
Nothing concerning there, provided you get a proportional increase in oil pressure with rpm.
Old Mar 27, 2025 | 04:17 PM
redzg's Avatar
redzg
Yep. Had it right in my head, but wrong at my fingertips.
Old Mar 27, 2025 | 04:58 PM
lespaulr0cker's Avatar
lespaulr0cker
My C5 oil pressure was reading fairly low at one point which was concerning. After replacing the factory oil pressure sensor the readings became normal again.
Old Mar 27, 2025 | 05:42 PM
namvet6869's Avatar
namvet6869
It does increase with rpm.
Old Mar 27, 2025 | 05:56 PM
frodo84's Avatar
frodo84
Uneducated autodidact
IIRC, the rule of thumb for LS engines is a minimum of 10 psig for each 1k rpms.
Old Mar 28, 2025 | 10:17 AM
grinder11's Avatar
grinder11
You are correct, of course. But it really won't do much, if anything. The only thing it would do is reduce flow a small amount. If you would run 6 qts of STP the pressure would probably peg the gauge, but some components would be somewhat starved for oil. OP-How old is your oil sender? If it's 10 years old, or older, I'd change it in the comfort of your garage. Beats a big oily mess when it does fail somewhere inconvenient. Then you should have both peace of mind on sender failure AND sender/gauge accuracy. Also, do not buy a GM sender. I bought mine at least 6 or 7 years ago at O'Reillys. It wasn't the lifetime guaranteed one, either, but I've never had another problem with oil pressure senders. Your pressure readings aren't terrible, but should be a little higher. I also run Mobil 1 0w-40, FWIW......
To oil pressure
