Getting up to temp very fast
Old Apr 4, 2025 | 05:28 PM
Eddie0311's Avatar
Eddie0311
Originally Posted by lucky131969
You can't just change the hose and top of the reservoir. You have to get the air out. Follow the service manual procedure for draining/filling.
haven’t put the hose on yet was just saying I topped it off for now till the hose gets here and the car was doing fine, but trust me I know what I’m doing considering I have done everything myself to my car minus tuning.
Old Apr 4, 2025 | 05:32 PM
Eddie0311's Avatar
Eddie0311
He may be OK without purging. BUT, I do agree with you. It's usually best to follow established procedures. OP, the best way to do this is to elevate the front tires a couple of feet in the air while the rear tires are on the ground. Use a floor jack or if you have a hilly yard, whatever. Remove the recovery/expansion tank cap (ONLY WHEN COLD!!). Start the car and add the coolant. HOWEVER, and this is a "while you're in there" thing, this would be a great time to flush the old coolant out and add all new antifreeze mixed 50/50 with either deionized or distilled water. If your coolant is fairly new, just slowly add a fresh mix of 50/50 coolant......
I have the snap on vacuum coolant filler/pump tool gonna just use that to put a vacuum on the system and properly fill it.
