Name That Part!
Old Mar 26, 2025 | 12:05 PM
jdm767's Avatar
jdm767
Default Name That Part!
Hello all!
Got a weird vibration under load... Real smooth in neutral (and 6th gear is like butter!!) but not so much in the other gears. So I did what most of us would do, I thought that I'd start digging in an would hopefully find the issue.
So I dropped the exhaust and removed the tunnel plate. Looking at the back of the bell housing, I found this:
I guess the last mechanic who worked on this thought that GM engineers put too many bolts into the car!
So, question is, what type and size bolts are they (and yes, I realize that the 2 horizontal bolts (not the ones on the carrier plate) are not the same as the single one higher up on the housing), and, where can I buy them???
Now, I know that these missing bolts aren't the source of the vibration, so back to the base problem...
If this were you, and you're appreciated experience, where would you look first? A couple of pieces of information: The engine was built about 5,000 miles ago. 383 stroker, forged Eagle running gear. The torque tube, axle and couplers were all new at the time of the build. The transmission was upgraded to a stage 3 T56 sometime before I bought the car. Differential has never been opened (that I know of) and the half shafts are original...
I hope you love a challenge.
Any help on the missing bolts and the vibration would be GREATLY appreciated.
Thank you!
Jeff
Old Mar 26, 2025 | 12:13 PM
lucky131969's Avatar
lucky131969
...and what about the bolt locations not pictured? Did you check if they are there?
Old Mar 26, 2025 | 12:20 PM
jdm767's Avatar
jdm767
Not yet! But I did find a rather large diameter bolt on the floor... oh boy.... I'll post a picture of that one when I get home next week...
Old Mar 26, 2025 | 01:16 PM
Dads2kconvertible's Avatar
Dads2kconvertible
Get ready for some thread repair.
Old Mar 26, 2025 | 01:30 PM
1Hotrodz's Avatar
1Hotrodz
Check the harmonic balancer to see if it has shifted on it's hub. check the driveshaft inside the tq. tube for excessive play. Those missing bolts worry me, who knows what else is missing especially on the stuff you can't see. Trans input shaft end play? Start digging deeper. That's all I have! Good luck.
Old Mar 26, 2025 | 02:36 PM
Rick@RKT Performance's Avatar
Supporting Vendor
St. Jude Donor '08-'09-'10-'11-'12, '14-'15-'16-'17-'18
Originally Posted by jdm767
Hello all!
Thank you!
Jeff
Jeff,
PM us, we have everything you need. Just pay for shipping.
__________________
Old Mar 26, 2025 | 07:27 PM
feeder82's Avatar
feeder82
Originally Posted by Rick@RKT Performance
Jeff,
That's great thing for you to do!
Old Mar 26, 2025 | 08:26 PM
Supporting Vendor
Old Mar 27, 2025 | 05:49 AM
jdm767's Avatar
jdm767
Thank you Rick! Very kind...
Old Apr 6, 2025 | 07:37 AM
jdm767's Avatar
jdm767
Quick update - the bolts arrived on Friday. Rick, thank you VERY much for your help and generosity. I hope to be able to return the favor someday.
Jeff
Old Apr 6, 2025 | 10:51 AM
Supporting Vendor
Jeff
All good. I hope you get the issue repaired soon.
To Name That Part!
