Harmonic Balancer
Old Mar 29, 2025 | 06:40 PM
Bearpen13's Avatar
Bearpen13
Default Harmonic Balancer
Looking for new HB for my c5. Seems like there are failures even on some of the aftermarket dampers. Would appreciate others opinions. Thx.
Old Mar 29, 2025 | 07:26 PM
VetinaVette's Avatar
VetinaVette
ATI Super Damper off Summit Racing. Since it is a critical part of the engine, I put it on my C5 even though I have no plans of super charging, etc.
Old Mar 30, 2025 | 09:01 AM
Gordy M's Avatar
Gordy M
My car is an autocross HPDE one and I pinned the stock HB and it held up until I broke a lifter. The car live in the 4000-6000 rpm range so the OEM balancer held up. If you are DIY then get the aftermarket lifter unless you have degree attachment for your ratchet. ARP bolt is tightened to torque and OEM bolt is degree of stretch
Old Mar 30, 2025 | 10:11 AM
grinder11's Avatar
grinder11
Aftermarket balancers may occasionally fail. However, I have never seen that happen and I would be willing to bet the OEM balancer has a higher failure rate than good aftermarket balancers. For reference I've run the same ASP 25% UD balancer on my LS7 engined C5 for nearly 20 years/80,000+ miles. It has outlasted 2 427 engines......
Old Mar 30, 2025 | 11:14 AM
pjdbm's Avatar
pjdbm
I went with the Dayco/PowerBond PB1117N with good results, however if i were to do this again (I really dont)
I would have spent a little more and get the ATI or the Fluidampr just because I don't want to do that job again.
Old Mar 30, 2025 | 05:34 PM
vette4fl's Avatar
vette4fl
X2 for the PowerBond. All of these, except Fluid Damper and TCI Rattler, use an elastomer, even ATI. The ATI and Summit are SFI safety rated for racing.
Old Mar 30, 2025 | 06:36 PM
hyperv6's Avatar
hyperv6
The SFI standard is highly regulated and shows the balancer will hold up to more than you will ever throw at it.
The ATI and Summit balancers are the gold standard.
The choice of the market generally is the Summit balancer with most LS builders. They are bullet proof and much less expensive vs the ATI.
Anything MFG can fail but with the racing SFI rating it shows the higher standard of mfg for RPMs you will never see on the street.
Old Mar 30, 2025 | 10:08 PM
lespaulr0cker's Avatar
lespaulr0cker
I just put in the Summit one and am happy with it…
https://www.summitracing.com/parts/sum-c2501
Old Mar 31, 2025 | 12:32 PM
johnson-rod's Avatar
johnson-rod
I put in whatever Amazon ACDelco was selling. It's been fine for 5 years so far. Not a race car.
Amazon Amazon
Old Mar 31, 2025 | 01:12 PM
vette4fl's Avatar
vette4fl
https://www.amazon.com/dp/B0049Z6VQE...d_asin_title_1
Hey, I get it. For example, if the original GM water pump gave up, I would install a new GM water pump. The GM dampeners have lasted for years and years, and in many, perhaps most, cases never failed.
Where I parted ways on the GM dampener was recognizing the damage that could occur upon failure. Also, better and affordable replacements parts are available unlike other components, like a water pump for example.
Most importantly, is that changing out the GM part has the implied requirement to swap the cam “while you’re in there”. So there’s that, lol.
Old Apr 1, 2025 | 10:21 AM
vettebk's Avatar
vettebk
My 2000 C5 with 67K mostly weekend miles started the famous wobble of the stock HD now more than 25 years old. I replaced it with ATI Super and it was also pinned. Car runs so much smoother now. Previously had a vibration at 1200 rpm through 2000 rpm on every shift, very irritating, and now completely smooth over the entire rpm spectrum. Very happy. And no wobble now!
Old Apr 1, 2025 | 11:29 AM
grinder11's Avatar
grinder11
Just a FWIW......I have been running an Edelbrock replacement Hi-Flow water pump (part# 8896) since 2014 and have never had a problem with it. If I do it is rebuildable. I paid about $300 for mine in 2014. I see they're around $475 now. Again FWIW....
Old Apr 4, 2025 | 01:32 PM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
I went with ATI, "just because"........
To Harmonic Balancer
