Service manual pdf
Old Apr 1, 2025 | 10:40 AM
jdm767's Avatar
jdm767
Default Service manual pdf
Does anyone have a recommendation for a pdf version of the 2003 Service Manual? Hard copies at $250 and up seem a bit excessive. A pdf would be fine BUT it's hard to tell from the websites which ones are legit.
I've searched this forum without any luck, so I turn to the vast knowledge base of this awesome group!
Thank you!
Jeff
Old Apr 1, 2025 | 10:55 AM
Smoken1's Avatar
Smoken1
At the top of the General Section is a sticky with it
https://redirect.viglink.com/?format...4.zip%3Fdl%3D0
Old Apr 1, 2025 | 10:59 AM
lucky131969's Avatar
lucky131969
Price v/s value.
Old Apr 1, 2025 | 11:43 AM
Dads2kconvertible's Avatar
Dads2kconvertible
The .pdf is ok but it's very disorganized. There are hundreds of 'sub-pdfs' that make searching impractical for the average user.
The printed manual is far, far easier to use. If you're actually going to be working on your car and those two are your only choices the printed version gets my vote.
I've heard good things about AllData, not sure if they have info on the C5. IMO a good index and search function is key to any electronic version.
Old Apr 1, 2025 | 02:28 PM
jdm767's Avatar
jdm767
Thank you all...
I've looked at the one posted here and it seems to skip over 2003. Is that because 2002 and 2003 are virtually the same?
I'm also going to check out eBay.... maybe there's a decent price on a paper copy there.
Old Apr 1, 2025 | 02:51 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
Thank you!
Jeff
You can get a 1 month, 1 or 3 year subscription on Alldata DIY for $19.99 if you only need it for a month…all Service Info and OEM wiring diagrams…it’s the best for a DIY’er…you can print out what you need…this is good for wiring diagrams.
Old Feb 6, 2026 | 06:08 AM
madebyme's Avatar
madebyme
1st Gear
I’ve been looking for the PDF too, so thanks for the Alldata DIY tip. I think it’s a great solution. But yesterday I realized I couldn’t open my saved PDF manuals. I had to convert them to another format with a free online tool https://onlydoc.com/png-to-pdf that I occasionally use when I need a reliable converter. It worked, and I was able to open the file, so if anyone runs into a similar issue, this might help. I think the problem was with my reader.
Old Feb 7, 2026 | 11:53 AM
sonata2.0T's Avatar
sonata2.0T
I bought a 1998 three volume service manual on ebay for $50 three years ago. There are electrical differences on the newer cars but most of the mechanical things are the same and it is much easier to find what you are looking for with the paper index. I also use the index to help find what I'm looking for in the free PDF.
Old Feb 8, 2026 | 05:13 PM
lucky131969
Originally Posted by sonata2.0T
There are electrical differences on the newer cars but most of the mechanical things are the same....
No so much. There are noteworthy differences between a 98 and 2004.
Air intake is different
Cylinder heads are different
Fuel system is different
A.I.R system is different
Air bag system is different
ABS system is different
Cooling system is different
IPC is different
PCM is different
To Service manual pdf
