Pfadt bushings install help
Old Apr 2, 2025 | 06:27 PM
Rwdirtbke's Avatar
Rwdirtbke
Default Pfadt bushings install help
I bought a Pfadt bushing kit and have a question hoping suspension guru's can answer as I haven't got a straight answer from the manufacturer. I noticed that there is a lot of room/gap between the bolt and sleeve for the rear upper control arms. Is this gap too big (I'm thinking the suspension will deflect by that amount under load) or is this normal?
Old Apr 3, 2025 | 11:53 AM
lucky131969's Avatar
lucky131969
How does the bolt o.d. to hole i.d. clearance compare to stock?
Old Apr 7, 2025 | 09:37 AM
JHrinsin's Avatar
JHrinsin
I installed an aFe PFADT poly bushing kit a few years ago. Why doesn't that tube section not ring a bell? Anyway which bushing number is this tube installed in (location) ? See the attached for reference. Also remember that once torqued down, that tube section becomes merely a crush limiter that is confined between the mounting tabs. It can't and does not move. The poly bushing itself is in between the tube and the control arm and that is what deflects. Plus you need some clearance between ID of the tube and the OD of the bolt for chassis variations and possible alignment tolerances.
Old Apr 7, 2025 | 09:36 PM
Rwdirtbke's Avatar
Rwdirtbke
These are the sleeves that go with 2371 & 2366 for the rear upper A Arms....Just didn't want the bolt to move within the sleeve and thus causing the the bushing to move by the same amount if that makes any sense. Thanks.
Old Apr 7, 2025 | 10:52 PM
JHrinsin's Avatar
JHrinsin
Once the nut / bolts are torqued to specification, the bolt nor the sleeve can move. The bolts applies a clamp load on the mounting ears on the frame, this then squeezes the sleeve between the mounting ears. The sleeve also acts as a crush limiter between the mounting ears. The sleeve and bolt are both "locked" into position, both to the frame and to each other. The A-arm with the bushing simply rotates around the captured sleeve as a pivot point. Hope that helps.
Old Apr 19, 2025 | 08:28 PM
Rwdirtbke's Avatar
Rwdirtbke
Just a bit of an update. The silver sleeves that I received are most definitely the wrong ones and then black ones they reshipped are correct. At first they appeared to be identical but after careful measurement they are not and they fit way better. Got the suspension back together but have now somehow lost a brake rotor 🤔. Ordered new ones to keep the build going. Anyway if you order a Pfadt bushing kit and you get silver sleeves. They are WRONG!
To Pfadt bushings install help
