C5 vert
Old Apr 3, 2025 | 09:28 AM
Joe Scafide's Avatar
Joe Scafide
Default C5 vert
Passenger window does not work with remote or door button have to open buy hand ?
Old Apr 6, 2025 | 05:03 PM
Alley Oop's Avatar
Alley Oop
Never had the problem myself, hopefully the following helps...
My passenger door window became stuck/busted the other day in the up position....push the down button and all i get is a "click" sound coming from the door....i'm thinking "ok, this is going to be a pain to fix"... not so!!!! i relate my woes to a good friend and he says to bring the Vette over to his house and he'll have it fixed in 5 minutes....I'M IN!!!!
Tools required:
1 small pocket screwdriver
1 long necked screwdriver
1 hammer
an assistant (unless you're a three armed mutant)
1st: remove the small cover on the door just down and back of the hand grip with the small screwdriver
cover removed:
next, align long necked screwdriver under the rear hex head bolt as shown:
now, while having the assistant turn the key to the "on" position and then repeatedly pushing the window "down" button, give the big screwdriver a couple of whacks with the hammer......window should roll on down.......
that is all.......
More posts….
I have tried all of the methods that I have found in this forum... I have taken the door and the window motor COMPLETELY apart 4 times ... But this one worked!!
I had fixed the motor "once and for all"... and found a way to keep it rolling. The thing is to remember to to this trick every time someone fiddles with the window (repair shops etc...) and rolls it up. I always let the window up all the way, and then down about 1/4 inch or less, by clicking the "window down" button twice really fast(it takes practice to be fast enough ). This relieves the pressure, and window won't get stuck. The window is open only a little, no water or other crap will get in
It's not the motor, it's the contacts. Hand-banging while pressing the button will work wonders, but the hard hit with the screw driver and hammer is more direct, cleans the contact with a jarring jolt, and since doing this same hammer move 3 months ago ... the pass-window works every time. Before ordering a new motor, clean, sand and crimp all the motor and switch contacts or solder them (solder is easy to remove when you need to). That's my 2 cents
Old Apr 7, 2025 | 09:07 AM
Joe Scafide
Default Remote
Thanks for info
To C5 vert
