agm batt
Old Apr 4, 2025 | 11:40 AM
curvet's Avatar
curvet
Default agm batt
2002 zo6 should I use a agm battery
Old Apr 4, 2025 | 03:54 PM
mmartinez's Avatar
mmartinez
Always recommended to use a AGM battery on a C5, because the PCM and TAC module are located beneath the battery.
Old Apr 7, 2025 | 11:53 AM
ztheusa's Avatar
ztheusa
Veteran: National Guard
Just "Cruzin' for a Bruzin'" if you don't.
Old Apr 7, 2025 | 01:35 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
Your Z06 came from the factory with an AGM so you want to stick with this type of battery…you don’t want acid spills or fumes in your trunk…the charging strategy for a lead acid vs AGM are different also …watch the video !!
Old Apr 7, 2025 | 01:50 PM
lucky131969's Avatar
lucky131969
...perhaps you are thinking of a C6
Old Apr 12, 2025 | 12:07 AM
Lowend's Avatar
Lowend
I would (and did) go AGM
Here's all the data you need
https://docs.google.com/spreadsheets...it?usp=sharing
To agm batt
