Leaded Gas Question
Old Feb 11, 2003 | 11:09 PM
Red C5's Avatar
Red C5
Default Leaded Gas Question
Are there any benefits or problems with running leaded gas? I know a lot of high octane racing gasolines are leaded.
Could I mix unleaded 91 octane with leaded high octane? Thanks. :cheers:
Old Feb 11, 2003 | 11:11 PM
Z06 Quin's Avatar
Z06 Quin
Default Re: Leaded Gas Question (Red C5)
It will kill your catalytic converters....
A catalytic converter relies on receiving the proper mix of exhaust gases at the proper temperature. Any additives or malfunctions that cause the mixture or the temperature of the exhaust gases to change reduce the effectiveness and life of the catalytic converter. Leaded gasoline and the over-use of certain fuel additives can shorten the life of a catalytic converter.
[Modified by Z06 Quin, 10:16 PM 2/11/2003]
Old Feb 11, 2003 | 11:15 PM
66ImpalaLT1's Avatar
66ImpalaLT1
Default Re: Leaded Gas Question (Z06 Quin)
And your O2 sensors.
Old Feb 11, 2003 | 11:18 PM
Red C5's Avatar
Red C5
What if I don't have any cats?
Old Feb 11, 2003 | 11:26 PM
Z06 Quin's Avatar
Z06 Quin
Then you don't have a problem....at least that's my take on it!.....the lead is only added to increase the octane rating above 104 (I think the race gas at the track goes up to 104 before lead is added).....now what you would need >104 octane is beyond me......
Old Feb 11, 2003 | 11:31 PM
kewlbrz's Avatar
kewlbrz
Cruise-In II Veteran
Cruise-In III Veteran
Besides increasing octane, leaded fuel also burns cooler. This is also the reason hardned valve seats were added to heads when the industry switched to unleaded.
You want to use the least amount of octane without producing knock (preiginiton) to develop the most power, since higher than needed octane ratings reduce engine output power and also cause the potential for more deposits in the combustion chamber. Octane rating has nothing to do with a fuels ability to make power. Just an anti-knock rating.
[Modified by kewlbrz, 10:37 PM 2/11/2003]
Old Feb 11, 2003 | 11:57 PM
kp's Avatar
kp
I have mixed unleaded and leaded race fuel in quite a few cars, with no cats the only thing you will do is shorten the life of your O2s. I will run 50/50 104/93 when I go to the track with this car (~11:1) just not to worry about detonation. I wish they sold 100 unleaded around here but they dont. I used to do the same thing with my supercharged cars as well and never killed a sensor, even if I do they are only 35.00 each..
If you dont need it though its a waste of money, but I assure you KR or detonation will kill more power then a few octane points..
Old Feb 12, 2003 | 12:29 AM
vetterdstr's Avatar
vetterdstr
CA Events Coordinator
Why not run the 100 octane unleaded they have here locally? Is the other fuel cheaper? YOu can setup your car for 91 and still have mucho HP. If you did that you would only need to run the 100 blend on very hot days.
vetterdstr :cheers:
Old Feb 12, 2003 | 05:56 PM
JCR's Avatar
JCR
Lead will increase carbonization and foul plugs faster.
To Leaded Gas Question
