Question on needing lowering bolts with z06 spring.
Old Apr 6, 2025 | 08:48 PM
JTsTOY's Avatar
JTsTOY
Sergeant
Default Question on needing lowering bolts with z06 spring.
Does the base c5 need lowering bolts when using a z06 rear leaf? I put a z06 spring in, but temporarily let the car down from the lift, and it seems higher than before. I jounced it up and down with no further settling. I did not drive it yet as I still have other work im doing. This is with leaving 2 threads above the nut, as per the service manual minimum. This is on my 2000 model. Any thoughts would be appreciated.
