Relocated MAT Sensor
Old Feb 12, 2003 | 08:05 AM
EMILLE3's Avatar
EMILLE3
Default Relocated MAT Sensor
Does the recalibrated and relocated MAT sensor make any difference? Should I just relocate the stock sensor?
I purchased the kit but have read on here that the recalibration doesn't seem to work well on a 99. I purchased new intake items and want to locate this sensor right the first time.
Thanks.
A first time owner and having fun buying goodies... :auto:
Old Feb 12, 2003 | 08:30 AM
vetterdstr's Avatar
vetterdstr
CA Events Coordinator
Default Re: Relocated MAT Sensor (EMILLE3)
Do not waste your time or money on this mod.. :nono:
vetterdstr :cheers:
Old Feb 12, 2003 | 10:26 AM
Jettech's Avatar
Jettech
Default Re: Relocated MAT Sensor (vetterdstr)
I agree!!!
Old Feb 12, 2003 | 11:36 AM
UtahVince's Avatar
UtahVince
I bought it and installed it on my 98 many years ago. Don't really know if does anything though. It is basically a timing advance trick. It gives the PCM a lower temperature reading of the incoming air, thereby allowing more timing advance.
Old Feb 12, 2003 | 11:44 AM
vetterdstr's Avatar
vetterdstr
Default Re: Relocated MAT Sensor (UtahVince)
Here is what I suggest to everyone who ahs this Mod on a C5. Hook up an Auto tap or Ease program and see how it runs with and without the Relocated MAT sensor on the car. Chances are... your car is better dialed in with it off the car. :yesnod:
vetterdstr :cheers:
Old Feb 12, 2003 | 04:03 PM
TLewis4095's Avatar
TLewis4095
And if after reading these opinions anyone still wants one I have one new in the box for cheap!! :cheers:
Old Feb 12, 2003 | 04:54 PM
EMILLE3's Avatar
EMILLE3
Thanks all. I purchased a PowerDuct. Should I relocate the stock sensor or just install it where it is presently located on the stock duct?
Sorry for all of the questions.
:grouphug:
Old Feb 12, 2003 | 07:02 PM
TLewis4095's Avatar
TLewis4095
I believe I installed it in the stock location....anyone else?
Old Feb 13, 2003 | 12:49 AM
Racer1x's Avatar
Racer1x
Get the timing trigger it plugs right in and you disconnect the sensor,keeps the timing advanced all the time.
Old Feb 13, 2003 | 06:05 PM
EMILLE3's Avatar
EMILLE3
Looks like i'll just install the stock sensor in the stock location then unless someone recommends otherwise.
THanks! :)
Old Feb 13, 2003 | 09:09 PM
Racer1x's Avatar
Racer1x
You should really try the timing trigger its cheap and makes a sotp difference.
Old Feb 14, 2003 | 12:23 AM
wickedvette's Avatar
wickedvette
Cruise-In II Veteran
Cruise-In III Veteran
I reinstalled mine in the stock position on my carbon fiber powerduct with no problems. I previouly had a "timing tricker" installed and ran into timing advance problems in warmer weather.
Old Feb 18, 2003 | 05:53 PM
EMILLE3's Avatar
EMILLE3
Default Re: Relocated MAT Sensor (wickedvette)
Thanks. I'll stick to the stock location then.
To Relocated MAT Sensor
