Rear Sway Bar Brackets
Old Apr 15, 2025 | 12:49 PM
phuz's Avatar
phuz
Default Rear Sway Bar Brackets
Is there another vehicle that uses a sway bar bracket that will fit the rear of the C5? I'd like to find something quick if possible since we have some nice driving days coming up.
Bonehead move yesterday: replaced sway bar end links and bushings, got sidetracked, never tightened the brackets, went for test drive, right side gone. Rule of thumb: stay focused.
Old Apr 15, 2025 | 01:41 PM
Beast's Avatar
Beast
Call a boneyard, go get your self some brackets.
Old Apr 15, 2025 | 01:50 PM
phuz's Avatar
phuz
Yep, just confirmed with a buddy that has a chevy dealer, that those are discontinued anyway. Luckily, being a garage pack-rat has paid off. Found a set of brackets laying around that just needed the slighest bit of bending, and found a nut and bolt in my random box of nuts/bolts.
Old Apr 16, 2025 | 02:16 PM
JHrinsin's Avatar
JHrinsin
The factory brackets were design to capture and contain the bushing so that they can't move laterally on the bar itself. I would recommend that you keep an eye on those bushings just encase they try to work themselves loose from under those brackets. There are new ones on eBay for under $17 each, as well as clean used pair for about $21 shipped;
https://www.ebay.com/itm/365437226285
Old Apr 16, 2025 | 03:12 PM
cdee63's Avatar
cdee63
2024 C5of the Year Finalist - Unmodified
^^They must not have worked real good as I noticed on the C6 bar I picked up they have a collar outboard of each mounting bushing keeping the bar centered.
Old Apr 16, 2025 | 05:27 PM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
Originally Posted by phuz
.......... Found a set of brackets laying around that just needed the slighest bit of bending, and found a nut and bolt in my random box of nuts/bolts.
They look like Energy Suspension brackets.........
Old Apr 18, 2025 | 04:49 AM
hunt4cleanair's Avatar
hunt4cleanair
A few weeks ago I picked up a couple of these from Rock Auto...seems like they were $7 a piece.
Old Apr 18, 2025 | 10:30 AM
cdee63's Avatar
cdee63
Or pick up some C6 versions. I don't know if because they came off a Z06 but the bracket is much beefier than the C5 one it replaced.
Old Apr 21, 2025 | 09:40 AM
JHrinsin's Avatar
JHrinsin
The later C6, XLR-V mount brackets GM #25933429 have replaced / superseded the older C5 and early C6 mount brackets GM #10426591 and #15142776
Old Apr 21, 2025 | 11:29 AM
cdee63's Avatar
cdee63
Yes, those are what I have, much heavier gauge metal than my C5 versions.
Old Apr 21, 2025 | 12:14 PM
JHrinsin's Avatar
JHrinsin
If I had to guess, those were most likely developed to deal with the C6 ZR1 31mm rear sway bar.
Old Jun 4, 2025 | 02:44 PM
JHrinsin's Avatar
JHrinsin
Finally was able to round up a pair of my own off eBay. NOS still in the GM service parts bag. Very heavy gauge steel.
Old Jun 8, 2025 | 03:34 AM
vette4fl's Avatar
vette4fl
If they still have stock would you kindly pm a link?
Old Jun 8, 2025 | 10:10 AM
JHrinsin's Avatar
JHrinsin
This is were I ordered the second one from.
https://www.ebay.com/itm/135012203958
To Rear Sway Bar Brackets
