Active handling/abs light + codes
Old Apr 21, 2025 | 01:24 PM
mattiC5's Avatar
mattiC5
4th Gear
Default Active handling/abs light + codes
Hey everyone, just picked up a 57k mile 2001 C5, drove it 5 hours back home with the ABS/ACTIVE HANDLING lights on. Owner was on top of maintenance and recently put new rotors, brake pads, and had the brakes serviced. However I still pulled codes...
28-TCS
  • C1214 H
  • C1222 H
  • C1226 H
  • C1283 H
I have heard of ABSfixer, but want to try anything myself before I go that route. Thank you for your time, any help is appreciated.
Old Apr 21, 2025 | 01:44 PM
Dads2kconvertible's Avatar
Dads2kconvertible
This might get you started. Good luck.
File Type: pdf
Old Apr 21, 2025 | 03:29 PM
lucky131969's Avatar
lucky131969
28-TCS
  • C1214 H
  • C1222 H
  • C1226 H
  • C1283 H
So you did not clear the codes before taking ownership, or they came back?? What is the history here?
Old Apr 21, 2025 | 10:29 PM
mattiC5's Avatar
mattiC5
4th Gear
I did not clear the lights or codes I saw them when buying the car and figured it can just be a faulty EBCM, the seller said his late father went to service the brakes for the ABS light. He drove it a VERY few miles (UNDER 50) before having to sell the car and the light stayed on. I will drive it some more to see if it disappears.
Old Apr 22, 2025 | 09:54 AM
lucky131969
Ok....so why are you not clearing the DTCs?
Old Apr 2, 2026 | 11:18 AM
CMC Corvette's Avatar
CMC Corvette
Cruising
Any code ending with an "H" means is has triggered in the past but not a problem now. "C" means it is a CURRENT issue!
To Active handling/abs light + codes
