Front steam port needed?
Old Apr 22, 2025 | 09:01 PM
FairHairWarrior's Avatar
FairHairWarrior
Cruising
Default Front steam port needed?
Hey everyone, I just installed some new (to me) 243 heads on my ls1. After I got everything installed, I noticed one of the front steam ports on ONE of the heads was blocked off in the casting. I suspect that one of the heads was from a ls6 and the other from a truck motor. Anyway to make it all work, I’d have to block off the other front port and only have a crossover on the rear. I’m under the impression that the front ports are more important. Will that cause any issues? Would going to the (large) effort of flipping the heads be worth it?
This is my first LS build so any help would be appreciated. Thanks!
Old Apr 24, 2025 | 09:39 AM
redzg's Avatar
redzg
Haven't pulled heads on an LS, but the tech people over time have noted that the front steam ports are the highest point in the cooling system, and the most likely to collect air. On the motors with only 2 ports, those ports are the front pair -- and mother GM doesn't put in any money they don't have to.
Old Apr 25, 2025 | 10:55 AM
PaulWall's Avatar
PaulWall
I agree. You gonna solve that at some point either with a new head or milling it out. I do have an extra set of remanufactured 243 heads brand new looking if you need a pair. I didnt pay a crazy amount so it could be a cheaper option for you.
Old Apr 25, 2025 | 11:12 AM
lucky131969's Avatar
lucky131969
Old Apr 29, 2025 | 04:45 PM
Mc556's Avatar
Mc556
They should be both marked with 243 on the casting or 799 etc. Is it welded up, capped off or just not cast into the head? Pics would be helpful. Personally I run with all 4 vented with a motion raceworks crossover kit. It’s your motor, but the vents exist for a reason.
To Front steam port needed?
