Cylinder head recommendations
Old Apr 27, 2025 | 09:24 PM
Ezra82106's Avatar
Ezra82106
Default Cylinder head recommendations
Hey guys, I am running a Texas Speed torquer v2 cam (232/234, .600/.600, 112 LSA), i am looking to get new cylinder heads for some extra power and am wondering what my best bet would be? would getting some used 243 heads and having them ported be the best budget option? i do not want to spend more than 2k. also what about piston to valve clearance? i run 7.4 inch pushrods like stock. if i do get 243 heads how can i have the worked to add more compression and increase CFM? thanks in advance
Old Apr 28, 2025 | 12:42 AM
Lowend's Avatar
Lowend
I really like the Golen Heads, which are ported 243's
https://golenengineservice.com/produ...omplete-heads/
Old Apr 28, 2025 | 08:06 AM
Prop Joe's Avatar
Prop Joe
New TSP Brawler heads. They will most likely have a Memorial Day sale... They do sell out of these though. These were not available when I did my Head/cam header/ upgrade, if they were I would have went this Brawler route. I have Currently TSP CNC ported 243/LS6 heads...
https://www.texas-speed.com/p-18424-...retainers.aspx
Summit offers what appears to be an AFR head under their name. Price is per head so you need two. I do not know of anyone running these yet. I just saw the offering about a month ago (64 and 67cc versions):
https://www.summitracing.com/parts/sum-162ls210cath
Looks to re branded version of these AFR heads:
https://www.summitracing.com/parts/afr-1501
One thing I noticed is that the TSP offering has a 5 angle valve job and the AFR/Summit is 3 angle...
Edit: You need to check pushrod length. Also good to check piston to valve clearance on any high lift cam.
Old Apr 28, 2025 | 09:54 AM
Mc556's Avatar
Mc556
I’m running some Texas Speed 5.3 stage 2.5 heads making 453whp with BTR stage 3 cam. ( GM 706/862 heads from 99 and up 4.8 and 5.3 motors) They have smaller combustion chambers so more compression. You will make more power below the curve with the extra compression which will help make up for the larger cam.
Don’t underestimate these as you can grab a set for a core at almost any junkyard cheap send them in to get cnc ported with larger valves, springs etc ready to bolt on for around $1400.
$1124 for TSP service and you supply the core.
www.car-parts.com is a salvage yard search service or FB marketplace for heads for a core. I got mine turn key from TSP and they already had a set for a bit extra. If you have or get a set of 243’s you can have the same done to them but I’d recommend having them milled for some extra compression unless you are going to run a 89 octane tune which would be silly.
Texas speeds PRC heads as cast are $2k and do not flow as much as the cnc ported GM heads. The CNC PRC do flow more but cost $3000. Your not going to outflow that cam with your 5.7l motor. Use your savings to get a LS6 or better yet FAST manifold.
Old Apr 28, 2025 | 11:42 AM
gtrslngrchris's Avatar
gtrslngrchris
The cnc ported brawler ls6 heads are $2k which is one of the reasons I just put a set of them on myself.
Old Apr 28, 2025 | 05:40 PM
Mc556's Avatar
Mc556
I was looking at the PRC .227 Cathedral Port that were $3k I see the Brawlers for $2k and under Texas Speed as the brand.
Looks like the flow numbers are dead on for the ported 243 heads.
Not a bad deal unless you already had a set of 243s to send in
Old Apr 29, 2025 | 06:46 PM
Lowend's Avatar
Lowend
I should note, the best LS engine builder I know swears by the Trick Flow 215's
https://www.trickflow.com/parts/tfs-...olet/year/2002
But I haven't seen the damned things in stock anywhere in more than a year
Old Apr 29, 2025 | 06:53 PM
Mc556's Avatar
Mc556
TRE performance may have them.
Great heads but they will be in the $2600 for the pair.
Old Apr 29, 2025 | 08:09 PM
Beast's Avatar
Beast
Nobody ever mentions AFR heads. What’s up with those?
Old Apr 30, 2025 | 09:01 AM
LannyL81's Avatar
LannyL81
I purchased the Summit Racing LS1/LS6 (AFR) heads. Not installed yet, so not able to comment anything about performance.
The difference between the Summit heads and the AFR Enforcer heads is unknown due to incorrect information and lack of details.
Summit has the max lift stated incorrectly at 0.660" at one spot, then the correct 0.600" in the specs.
Summit specs state no steam ports; the set I have both have steam ports.
Summit also states that roller rockers are required due to the manganese-bronze valve guides. AFR just states bronze valve guides; nothing about requiring roller rockers.
So, if the AFR Enforcer heads do not require full roller rockers, there is no $$ savings in getting the Summit heads over the AFRs as the cost difference in a BTR V2 trunnion upgrade and roller rockers eats-up the difference.
Lastly Summit "tech" told me that these heads were an improvement over the stock 243 heads.
If anyone wants any detailed pictures of the Summit heads, let me know. They are just sitting in their boxes on my bathroom floor waiting for June.
Later,
To Cylinder head recommendations
