Power Steering Cooler Bolts Broken
Old Apr 28, 2025 | 12:52 AM
Jet Black Jim's Avatar
Jet Black Jim
2nd Gear
Default Power Steering Cooler Bolts Broken
Hey all, I’m replacing the harmonic damper on my 03 Z06 and in removing the power steering cooler, both bolts broke off flush. I am having a hell of a time getting them out.
Thinking about drilling new holes 1/2” to one side, and maybe 1/4” below. Has anyone else here had to deal with this? Any other suggestions?
Old Apr 28, 2025 | 01:08 AM
Mr. Black's Avatar
Mr. Black
No Hostility Be Happy
Mig weld nuts to them. Wrench them out hot. They will come right out.
If no welder take a torch to them and start drilling them while they are hot and the will likely break free. Using like a 3/16 bit. Iirc those holes are not blind.
Old Apr 28, 2025 | 03:37 AM
Tusc's Avatar
Tusc
Running Guns & Moonshine
Listen to the man.
His idea is best if you can get to the bolt heads with a welder.
Another option is to pull the accessory bracket itself from the car with the pump. Once out you can pull the pump off and eject the bolts.
If you happen to still have the factory plastic pulley on the pump which we all hate, just crack that thing off for easy access and replace with a $25 LS2 metal PS pulley.
Old Apr 28, 2025 | 02:28 PM
lucky131969's Avatar
lucky131969
Originally Posted by Tusc
Listen to the man.
Not following here. The factory PS cooler attaches to the cradle, no?
Old Apr 28, 2025 | 02:32 PM
Tusc's Avatar
Tusc
Oh dang. I think I read that at 3am and missed the "cooler" part. That is infinitely easier to correct and remove.
Old Apr 28, 2025 | 07:07 PM
Mr. Black's Avatar
Mr. Black
lol tusc, we've all been there.
anyways, it took a minute but I was able to look at my front cradle and the bolts do go all the way through the wall of the cradle for the cooler clips. so you can see the threads poking out the other side.
I'm confident that if you take a small bottle torch and heat the broken bolts and then start drilling carefully they will like spin right out of the aluminum. Unless the OPs car is a completely rusty corroded basket case than they may just have to be drilled out and then put in longer bolts and nuts on the back side.
I suppose you could helicoil them but that is more trouble than it's worth IMO.
To Power Steering Cooler Bolts Broken
