C5 no AC
Old Apr 28, 2025 | 05:08 PM
Jason Ruiz's Avatar
Jason Ruiz
Navigator
Default C5 no AC
2000 c5 base with no ac! Bought the car and only had heat. On top of that it only blows air on max setting (5). Shortly after my heat went out too and i found a blown fuse for the blower motor. Car now blows hot again and now cool air but not really cold enough. Could it need refrigerent or new blower?
Old Apr 28, 2025 | 05:19 PM
ipuig's Avatar
ipuig
St. Jude Donor '09
Do have a set of automotive refrigerant gages, a multi-meter, a bi-directional scan tool, the factory service manual, and sufficient knowledge to adequately troubleshoot the system? If not, I recommend you take it to an automotive HVAC repair shop.
Old Apr 28, 2025 | 08:10 PM
bookyoh's Avatar
bookyoh
It sounds like you have multiple issues and without much vehicle history.
A simple, but crude test to see if the refrigerant side of your system is working: A/C on, blower high, someone holds the engine speed over 1000rpm and you feel the metal part of the suction line; it should feel very cold. If it is a hot humid day, the suction line should be sweating cold condensate as well. If it is only cool or warm, at a minimum you may be low on R134a. More serious things (expensive) may be wrong.
Old Apr 29, 2025 | 08:53 AM
redzg's Avatar
redzg
Your best option is to take the car to a trusted local shop. Can’t speak for others, but I don’t have one of those. Every shop I’ve been to has ended up being hacks one way or another.
You can learn a lot with a $40 recharge kit from Walmart or others. Just be sure it has a numbered dial gauge.
With the engine and system off for several hours, i.e. morning, connect the can to the low pressure port and see what static pressure is. It should be the same as ambient temperature. If it’s less then you need to add refrigerant. You can start adding until the system stabilizes at ambient equivalent pressure, then start the motor and A/C and charge to green zone on the gauge.
Old Apr 29, 2025 | 09:55 AM
PaulWall's Avatar
PaulWall
Id go refrigerent first being the cheapest before I get a compressor. I had the same issue and it was the compressor. Easier to replace than it looks just remove the header.
Old Apr 29, 2025 | 11:05 AM
Jason Ruiz's Avatar
Jason Ruiz
Navigator
What if the compressor isnt spinning? Can i still add refrigerent? I saw a video of a guy using a jumper wire to get it spinning. Should i go this route?
Old Apr 29, 2025 | 12:43 PM
lucky131969's Avatar
lucky131969
Have you evaluated the low and high side pressure with gauges?
Old Apr 29, 2025 | 03:02 PM
kmartinka's Avatar
kmartinka
I just went through a similar situation. My problem was the refrigerant leaked out and the compressor was the issue. I have learned the compressors have a high failure rate on these cars. My car came with AC UV dye installed from the factory, so it made it easy to see the problem on the compressor. The compressor was covered in UV dye. Some of the people on this thread helped me with my issue. They are very knowledgeable.
Old Apr 29, 2025 | 03:31 PM
redzg's Avatar
redzg
What if the compressor isn't spinning? Can i still add refrigerant? I saw a video of a guy using a jumper wire to get it spinning. Should i go this route?
No. That is definitely not a first step. One of the reasons to check your static pressure is to know whether there is sufficient refrigerant for the system to run. If your refrigerant is too low that alone will prevent the compressor from spinning, in order to prevent compressor damage. The gage on the EZ-Chill recharge kit from WallyWorld will tell you if you have the minimum you need to turn the compressor on.
When the car has been off for some time, the pressure in the A/C system equalizes between the high and low sides, and stabilizes at a pressure roughly equivalent to ambient temperature, i.e. if it's and 80 degree day, the static pressure will be 80 psi. If the system is static, and you have 40 psi on an 80 degree day, the compressor may spin just long enough to drop the pressure on the low side too much, and then the compressor stops again.
https://www.walmart.com/ip/EZ-Chill-...R&from=/search
Old Apr 29, 2025 | 04:23 PM
Jason Ruiz's Avatar
Jason Ruiz
Navigator
got it. Ill grab a can and see what happens
Old Apr 29, 2025 | 04:28 PM
lucky131969
Load it up!
Old Apr 29, 2025 | 07:01 PM
Jason Ruiz's Avatar
Jason Ruiz
Navigator
ok my psi is reading 0. Like nothing.
Old Apr 29, 2025 | 09:28 PM
bookyoh's Avatar
bookyoh
You have established that you have no refrigerant in the system. Someone needs to leak test your system and determine where the leak or leaks are. Should turn the compressor over by hand too and see if it turns smoothly or is crunchy like it is broken internally. Since the system has no refrigerant, it is easy to pull out the orifice tube and see if there are small chunks of metal.
Old Apr 29, 2025 | 10:48 PM
Midwest19942000's Avatar
Midwest19942000
You’re getting a lot of good advice here and are heading in the right direction. I would also finish checking on your HVAC controller to make sure the blower motor works properly at all speeds and that all of your vent modes work as they should. That way when you get the AC system repaired and recharged you know everything is working properly on the control side.
As for the absence of refrigerant, I had the same problem on my 2000 with weak AC and as stated earlier in this thread the compressor housing o rings are a common failure point which is what caused the leak in my system. The oil has dye in it and it was easy to see it leaking out around my compressor. I took the car to a shop and had them evacuate the system. Then I pulled the compressor and rebuilt it with a seal kit from Auto Zone (you can also just buy a new compressor). After inspecting the rest of the system I was pretty confident the compressor was my only leak point. Had it recharged and I’m on my third summer with ice cold AC.
Good luck and keep us posted!
To C5 no AC
